MTX 81000D LED 238 does not turn on and no audio
Some amps will go into low voltage protect if there is any significant resistance in the B+ line. That needs to be eliminated as a possible problem. An inline fuse (about 15 amp) will protect the amp if the FETs are clamped to the heatsink.
This is a self-oscillating amp. There won't be a high-frequency carrier unless the amp is in good working order.
Good Morning! I'm back. In the LM311M, what voltages should I have on pin 4 and 8?
In the LM311M I have 9.58v, on the other hand the PS wave deformed again and generated noise, because of that I decided to investigate the fet471 and 260, I changed the 260 that came with Irfb42n20d replacing it with a similar one and the PS wave It returned to being rectangular and without noise, only for a moment, it returned to deform and make noise, now I have a doubt. Are the fets you mentioned correct? fet 471 is 75339P and fet260 is Irfb42n20d?
The gates of the PS FETs doesn't have to have a square wave. This is a regulated supply so the waveforms won't be perfectly square. If you have the tutorial, look at the waveforms on the "MTX Power Supplies vs Other Amplifiers" page.
What relevance does D444 have?
Yes I have the tutorial but my CD is damaged and doesn't read, I kept several copies and unfortunately my wife deleted them from my 2 computers, that's why I haven't reviewed it
Good afternoon, I am following the tutorial, but is it normal to see so much noise in the waves of pin 2 and 3 of the a3120 and a little deformed in the wave in d473?
With a regulated supply, after the target rail voltage is met, you won't see a perfect square wave.
The noise on the input to the optocoupler is due to the reference. With an isolated scope (from the mains), place the negative scope clip on the terminal with no square wave and the tip of the probe on the terminal with the square wave.
