MTX 81000D LED 238 does not turn on and no audio
I was looking for a problem with the drive but it's difficult to do with nothing more than a 45Hz (low-frequency) signal. I didn't see a problem with the waveforms you posted.
Could the amp possibly have been going into low-voltage protection as it tried to power up with the two FETs in the circuit?
One of the output inductors looks like it got hot. Could it be defective?
I'm afraid if there is a damaged coil, but I don't have to measure inductance, is there another way to measure the coils?
If you see only a square wave of low frequency, in my opinion and not knowing this amplifier behavior particularly, looks that the amplifier isn't oscillating at the switching frequency, thus the filter's coil at 45Hz are only shortcircuits. Their Xl is too small.
the frequency of 45hz is a signal that I put from the rca, at one point I share a photo of the frequency that is given with fets inside the board, when removing the serial bulb that I have for protection, it immediately damages the d260 q263 and the d253 I can't figure out what damages them
sorry I couldn't show you the wave that it generates with the fets mounted on the board, again the components mentioned in the previous answer were damaged, also 1 3120 I will have to wait for more Hcpl3120 and mmsz5250 to arrive greetings
