MTB Manifold - Help Interpreting Impedance Measurements
Did you do basically open baffle boxes or more complex Greg?
No, relatively few OBs made from recycled table tops, doors or open back boxes and excepting the latest Paraflex 'craze' that I would never have considered worth doing before DSP, have over time either designed, 'oversaw', built, at least a copy or 'proof of concept' alignment of every 'flavor' of box alignment I've ever seen posted on DIY audio forums thanks to having easy access to folks with the necessary math skills, higher education to turn my intuitive thoughts WRT the 'physics of the situation' into meeting the needs of the intended app.
Reactions: Kravchenko_Audio
Sounds kind of familiar. Never a dull moment Greg.
Mark
One tip on measuring a horn. Take your measurements at least 4 or 5 metres away. It takes time for the output to sum. You literally can calculate the length required. Rule of thumb for most speakers if you don't want to do the math is 10 metres. You need enough volume to not have your measurement swamped by environmental noise. That is the only potential problem. Many enclosures are not so happy with this.
When building the cab, to get the driver in and out without rear mounting it with an access panel, I had to move it closer to the mouth. I never adjusted the simulation after this
Running the numbers again (with the correct driver offset), the sharp drop at 300hz occurs in the simulation. Note that the driver offset is indeed 1/4 wavelength of the null in the simulation, as LORDSANSUI suggested.
There we go - the build didn't match the sim 🙂
If you want some of that lost SPL back, try stuffing the closed end of the horn that's behind the driver. That should reduce the impact of the reflection from the closed end of the horn on the overall output.
That was suggested to him in the post #34 with an image.
"One simple test that may worth doing is to stuffing the Front Horn Throat like indicated in the black area of the attachment #3 with some fiber material, things that could damper the frequencies close to the dip, and see if you perceive any improvement."
It's easy to implement.
Hi @laxandredeyed
Did you ever get these equipped with the getshow plate amps? Your builds look great, especially the cabs for your friend's DJ setup you posted over on the other manifold thread. 🙂
I'm really impressed Lordsansui's design tools and this manifold design in particular, especially since it looks like something even I could possibly knock out with a track saw without the expensive CNC requirement. I'm a very crap woodworker. lol
@rrobot I never actually built the second box. I had plans to build new ones with a lower frequency response and less sensitivity, but they never eventuated.
I’ve equipped a few other boxes with the Getshow amps. I did have two amps that failed, but Getshow gave me free replacement parts.
My DJ friend’s boxes are still going strong.
Reactions: rrobot
A friend and I have also built a much larger box with similar layout with the intent of being a sub for DJing that will work down to 40hz. It's loaded with a 2226. Results for that, and the cabinet I have built will be posted once we've done the measurements.
I'd love to see the box for 2226, even if you don't have measurements just yet the plans would be of interest to me - would you be willing to share them?
I am curious weather your sim was also improved in the 55hz region, as your previous comparison showed a pretty significant decrease in spl in that area.
I would personally be way more concerned about that, than the dip at 300hz, as you will probably be crossing over way before that anyway. As @Brian Steele pointed out, the 300hz cancellation might be an advantage, as it tidies up some of the mess outside the bandpass.
Do you find the center of the cancelation area to be very closely related to the actual full wave length that ‘fits’ between front and rear location of the driver?
I notice in my measurements of this it’s the 192 hz (180 cm) (the green one)
