MOSFET Input, MOSFET VAS, MOSFET Output = 18 Watt
ALL MOSFET Amplifier.
THD at 1 Watt is 0.0008%
Harmonics shows most H2 and a bit H3.
Output should be at 17.9V and the bias is 1.20A.
Max output is like 18 Watt.
Tranformer should be 2x15VAC or 30VAC for like 40VDC supply.
Enjoy!
I notice you don't use source resistor such as 0.22 Ohm usually. U5 could be BD140 so that you can do thermal coupling to the output transistors.
I prefer tying C2 from the output stage instead of VAS. You want R1 and R4 see the same amount current changed. The C2 on VAS will make the current imbalanced.
Reactions: lineup
