Mosfet Amplfier
djk said:
"I also wanted to have defined input impedance (contrary to the ZEN)."
What part of 47.5K is not 'defined'?
http://www.passdiy.com/images/projects/zen-v4-f3.gif
Did you even bother to look at the schematic?
Dear djk,
For ZENV4, the input impedance is 47k. For original ZEN it was only 4.7k. Transfer function of the ZEN was greatly dependent on output impedance of the preceding signal source, as ZEN is an inverting circuit. This was especially problematic for earlier version (4.7k input impedance), now it is better. The mosfet follower was my reply to the original ZEN, ZENV4 is much newer design.
soundNERD said:
Where did 3V and 2V come from for the zener. The schematic calls for a ZD18V, or I think an 18V zener. I will look at Onsemi, but what wattage will I need?
3V zener is the one marked as ZD3V in the schematics (connected between base of TIP141 and GND. 18V zener is a protection to the mosfet. Small diode rated at 0.5W or 1.3W is OK.
soundNERD said:
Would this 18V zener work? it is from onsemi. I seperated the tables by lines here. Here is the original site: http://www.onsemi.com/site/products/searchproducts/0,4426,,00.html?searchString=18V+zener+diode
1SMB18CAT3
Zener SMB Transient Voltage Suppressor Clipper 600W 18V
Active
SMB
2 403A-03
Tape and Reel 2500
$0.28
Order Samples
Availability/Buy
A Transient voltage suppressor is not a regular zener, it is used to protect an appliance from voltage peaks that might occour.
And the fact that it is in a sample list doesn't make it more suitable than a few cents' zener (readily available in every electronic shop).
Cheers
Andrea
