which one is good..? in terms of transparency? I think Mosfet amps are good enough but I would like to know why Brystons use Transistors?
I think the terms you are looking for are:
Unipolar transistors (field effect devices)
Bipolar transistors (junction devices)
rhythmdiy said:which one is good..? in terms of transparency? I think Mosfet amps are good enough but I would like to know why Brystons use Transistors?
Both are good for amplifiers.
I have built my own using both and had very good results.
Personally I would stick to a tried and tested design.
Re: Re: Mosfet amp or Transistor amp?
Yes, both BJTs and FETs can give very good results in a good design, but both are capable of very poor results in a bad design.nigelwright7557 said:Both are good for amplifiers.
fet mosfet and bipolar
start with fet on input 2SK170/2SJ74 are very good
then for voltage gain stage better use 2 big mosfet like 2SK1058/2SJ56
For final stage are better bipolar 2SC5200/2SA1943
Complementary configuration is essential for ideal results
the architecture is traditional but without second current stage
sorry don't have good picture
Stee,
the second stage (VAS) uses jFETs in your posted schematic, not big mosFETs.
The capacitance of a 1058 would kill the mid and treble response of the LTP stage.
- Mosfet amp or Transistor amp?
