Hi Henry,
Thanks for testing 🙂
From what I've read this may get rid of CRDA messages. It appears the package not included in Jesse...
apt-get install wireless-regdb iw crda
reboot
Please post back output from
uname -a
Regards,
Tim
OK, I did that and now the message disappeared. name -a gives the following response:
Darwin adm-45102 15.3.0 Darwin Kernel Version 15.3.0: Thu Dec 10 18:40:58 PST 2015; root:xnu-3248.30.4~1/RELEASE_X86_64 x86_64
a quick test of the wifi. It works fine as well. Also, it does not stop when Moode are on without playing for half an hour.
Is that the hifimediy one ?
HiFime 9018i i2S DAC
and you are using the hdmi out from Pi to the hifimediy dac...?
No, not this DAC.
- One year ago, could not make it work with my DIY es9018k2m DAC, may be the wiring is too messy.
http://www.diyaudio.com/forums/digital-line-level/260906-my-diy-es9018k2m-dac.html
- Several months ago, successfully made it play PCM with tekdevice.com dacberry1 es9018k2m DAC, Pi 1 Model B+ and module based Volumio. But can not make it work with device tree based Volumio and DSD.
- A few days ago, downloaded moOde 2.5, play it with Pi 2 and dacberry1:
boot up moOde 2.5
select I2S device = RPi-DAC
reboot
Adjust volume to 75%
Bingo........what can I say.......
moOde 2.5..........simple and elegant, no need to tweak device tree anymore.
I've just set up a pi zero and a phat dac running 2.5 following Phil Randle's instructions from post #1313
Working perfectly
Rob
Working perfectly
Rob
Hi Henry,
Good to hear built in WiFi working 🙂
Please post following commands from the Pi.
(1) uname -a
(2) lsmod
Regards,
Tim
Tim, PM me your address and I'll scoot you over a Pi3.
Hi Mike,
Sure! Thanks so much 🙂
-Tim
2.5 works great.
Many little improvements here and there those surely improve the experience and usability.
The problem I had with covers was generated by the way I was handling the USB HDD folders structure.
I just stepped back the conventional way: rationalize the folder structure in the HDD and use .mpdignore files, instead of hard coding the music folder in mpd.conf.
This way it works as intended and covers show, as they should.
This 2.5 (plus that css fix posted in the previous page) feels like a pretty solid release.
good job!
good job!
Hi TimCurtis,
I expanded SD card storage to use extra space. When I transmitted my music files to Moode through Network, everything is OK. But I failed to connect Moode player when I copied files to SD card on a PC. These files were copied to /mnt/SDCARD. How can I cope with this problem?
Hi TimCurtis,
List the steps u used to "copied files to SD card on a PC"
-Tim
I copied my music files from HDD to SD card on Linux
Here were my commands:
sudo mkdir /tmp/myhd
sudo mkdir /tmp/myusb
sudo mount -t ntfs-3g /dev/sda1 /tmp/myhd
sudo mount /dev/mmcblk0p3 /tmp/myusb
sudo chmod -R a+rw /tmp/myusb
Then I used File Manager to copy files to /tmp/myusb/mnt/SDCARD
After I restarted Moode with changed SD card, I got “ERROR_CONNECTION_REFUSED” from web login.
Hi Henry,
(1) uname -a
(2) lsmod
Regards,
Tim
uname -a:Linux moode 4.1.18-v7+ #846 SMP Thu Feb 25 14:22:53 GMT 2016 armv7l GNU/Linux
lsmod:
Module Size Used by
arc4 1718 0
ecb 1963 0
md4 3375 0
md5 1783 1
hmac 2835 1
nls_utf8 1154 1
cifs 378619 2
nfsd 246576 2
ipv6 338574 50
snd_bcm2835 19802 0
brcmfmac 177546 0
brcmutil 5501 1 brcmfmac
snd_usb_audio 114378 1
cfg80211 389253 1 brcmfmac
snd_usbmidi_lib 19690 1 snd_usb_audio
snd_soc_bcm2708_i2s 6670 0
snd_hwdep 5595 1 snd_usb_audio
snd_rawmidi 18300 1 snd_usbmidi_lib
regmap_mmio 2842 1 snd_soc_bcm2708_i2s
evdev 10278 0
snd_seq_device 3445 1 snd_rawmidi
snd_soc_core 127477 1 snd_soc_bcm2708_i2s
rfkill 16036 2 cfg80211
snd_compress 7689 1 snd_soc_core
snd_pcm_dmaengine 3231 1 snd_soc_core
snd_pcm 73442 4 snd_bcm2835,snd_usb_audio,snd_soc_core,snd_pcm_dmaengine
snd_timer 18792 1 snd_pcm
snd 50779 12 snd_bcm2835,snd_usb_audio,snd_soc_core,snd_hwdep,snd_timer,snd_pcm,snd_rawmidi,snd_usbmidi_lib,snd_seq_device,snd_compress
i2c_bcm2708 4920 0
bcm2835_rng 1763 0
bcm2835_gpiomem 2860 0
uio_pdrv_genirq 2944 0
uio 7753 1 uio_pdrv_genirq
btw - I tried with the hifiberry+ pro I2S dac - with a weird reaction. when I press the play button it gave white noise, next time I pressed it worked, third time it worked with much reduced volume- it randomly shifts. With a USB dac it works fine.
henry
R-Pi 3 and HifiBerry Pro+ and Digi+
Raspberry 3 Problems with HiFiBerry, DAC+Pro and DIGI+ : Raspberry Pi • RuneAudio Forum
FYI
FYI
Just a friendly bump for those who wish to try on Pi-3 🙂
Regards,
Tim
Works great with my Audio-Gd USB-DAC 😀
(except for adding "dwc_otg.fiq_fsm_mask=0x2" in cmdline.txt, but that was also with Moode on my R-Pi B)
Thank you, Tim.
That makes sense. Thank you for the link
I thought that if u plug Moode sd card into Linux machine it can R/W the ext4 root partition directly?
-Tim
Very odd about the Library load quitting like that. My own test collection is 18K tracks and no issues, and I've received user reports of up to 40K tracks loading successfully with TR3.
I would troubleshoot by trying to isolate the directory that it appears to be having trouble with and then examine the files for anything suspicious. The Library is based entirely on the presence of Genre, Artist, Album tags. If any are missing in the file it assigns the string "Unknown genre/artist/album".
Did MPD DB UPDATE complete and successfully index all 69K tracks? A good indication of success would be that the last dir of files in the collection appears under Browse panel NAS.
Regards,
Tim
Hi Tim
I upgraded easily to 2.5, everything OK except that, as It was the case with 2.4, the library seems to be indexing forever. How can I fix it ? Everything looks OK in the Browse (although I have USB, USB2, USB3, USB4 while I am only using an ethernet NAS)
BR
Jean-LOuis
Hi Tim
BR
Jean-LOuis
The utility referenced at link below has worked for some.
http://www.diyaudio.com/forums/pc-based/271811-moode-audio-player-raspberry-pi-148.html#post4579654
Restart MPD from MPD config page and the extra unpopulated folders will not appear in Browse panel.
-Tim
Thanks TIM I'll try
the proper link fro TrackErr utility http://www.diyaudio.com/forums/pc-based/271811-moode-audio-player-raspberry-pi-50.html
-Tim
Tim, I tried to use USB instead of Realtek PCIE CardReader on my laptop to copy files, and it worked! I guessed that there is some driver issues with CardReader on Linux system. Anyway, Thank you.
- PC Based
- Moode Audio Player for Raspberry Pi
