I'm sure they're both good. I had a 24-position attenuator built with the 04 model. Very nice... But yeah. Pricy. I'm sure the 01 type is fine too. At least it comes with a real data sheet (and nice specs too).
Tom
Tom
I haven't had much problem with Lorlin switches myself but those are mechanically more solid in my experience : RS 263: Stufen-Drehschalter, 2x3 Pole, 3 Stellungen bei reichelt elektronik
Not sealed though.
edit: similar switches are sold by alpha on Mouser.
edit2: another option, quite common in the pro audio world, are the grayhill switches. Not cheap though.
Not sealed though.
Well, the Lorlin switches aren't really sealed. They are enclosed and that is about it. I work with the very old selector switches all the time that are open. No problem as the wiping action is effective with those, and then they are easily cleaned and lubricated.
-Chris
-Chris
Overall, the arrangement above looks reasonable. I would mount both MOD86 boards top side up. You aren't gaining anything by flipping the one on the right upside down.
Tom
Probably a long-shot, but I'm love it if you offer pairs of mirror imaged boards for your amplifiers. I'd pay extra for that to ease my OCD layout concerns.
I realize that probably won't happen, but never hurts to ask. 🙂
Mirror image? Tom goes to great pains to maximize the performance by careful layout. So you mirror-image the PCBs -- but the LM3886 won't be mirrored and neither will the op-amps. Likely an attempt at a mirror-image PCB (1) won't really be a mirror image and (2) will have worse performance because it will be different.
Too late for me but YES!
BTW - when I said "OCD layout concerns", I was referring primarily to aesthetics. Yes, it might be a silly request. But part of the DIY fascination (for me) is building and having it look good. Even if it has a cover that's rarely removed.
Yeah... Worse performance plus twice the inventory to manage (and update when TI decides to make parts go obsolete). That's a non-starter.
I do like when things look neat, though.
Tom
Tom
Read about Macintosh prototypes.BTW - when I said "OCD layout concerns", I was referring primarily to aesthetics. Yes, it might be a silly request.
Any comments would be welcome.
Thanks !
Seriously!?? ? Buy a Firstwatt kit of parts from the Diyaudio Shoppe. Ditch those bits or sell them on. Use that case.
The resultant amp will be Decidedly better sounding no if's ands or buts .. and cost same if not less $$.
ONLY caveat being the Firstwatt amps(s) are in the 20 /25 Watt range.
So one does need 'worth owning' Speakers. Poor gear will sound poorly.. the Firstwatts will reveal inadequacies.
As always..MANY roads to nirvana.. and not surprisingly, some are better than others.
G'luck
Reddo appears to be using the 2U Dissipante series from ModuShop (also available from the DIY Audio Shop). That's the chassis I recommend for the MOD86. I'm not sure why one would buy a kit, ditch some parts, and reuse the chassis. I understand that many roads lead to Rome, but why go the most expensive route?
Tom
Tom
Bare: you are joking I hope?
Bill, if you think Bare is joking, then you don't know him ... 😀
OTOH, Reddo's build looks like it's nicely coming along.
Oh, nothing... Just a little protection board. 🙂
Regular readers of this thread will know that many have requested a little protection board to guard against DC on the output of the amp. So without further ado, I introduce the Guardian-86.
Features:
The Guardian-86 is compatible with the Modulus-86, Modulus-286, and other single-ended (i.e. not bridged or BTL) amplifiers. There'll be a separate protection board for the Modulus-686.
Tom
Features:
- Mono construction.
- No relays! All switching is done with MOSFETs for lower distortion.
- No relay contacts to wear.
- Adds no distortion of its own.
- Floating photovoltaic MOSFET driver to ensure consistent good performance throughout the full swing of the output signal.
- 5-second delay on power-up. Output disabled when supply voltage falls below 20 V.
- Input: Molex Mega-Fit connector for easy connection to the Modulus-286 and screw terminals for the Modulus-86 and other amps.
- Output: Screw terminals and two 4.2 mm diameter holes at 3/4" spacing for direct mounting on the speaker output terminals.
- 2.50 x 1.75 inch footprint.
Tom
- Chip Amps
- Modulus-86 build thread
