Modulus-86 build thread
Proof of concept: I’m powering Mod86 10th Anniversary boards with my big separate dual +/-24VDC CLC power supply usually slated for class A amp duty. It sounds just lovely, with a totally silent background. :yes:
With a proper chassis, this will be my summer amp.
how long of a 2U heat sink would I need?
Long enough. 😉
It depends on many factors. How thick is the base? How many fins does the heat sink have? Are the fins serrated?
You can always punch your numbers in here: https://heatscapecal.com/natural Use the calculator to get you an estimate of the thermal resistance and device temperature.
If the heat sink is a ModuShop 2U x 200 mm, for example, you can probably squeeze two channels of Modulus-86 onto it. With an internal heat sink you can let the chip run a bit hotter as you don't need to worry as much about burning your fingers on the heat sink. If you design for a heat sink temperature around 70-80 ºC the chip will be fine. The amp will maybe get lukewarm during normal operation but will reach that 70-80 ºC with music at clipping levels for hours and a 4 Ω load.
Tom
Reactions: rockies914
