Mmats SQ2150
This is what I get for drive on the gate pads and it’s the same drive that comes right off the IC
Scope set to 10us 5volts/div
The 3525 is brand new .
Post 22 was with no capacitor.
With the capacitor installed I get no drive at all .
And pin 10 is still lifted with just power and ground hooked up the amp comes
On . But when using the scope to check drive the remote was connected to the amp
New ic installed with pin 10 lifted
Pin 1:0.00
Pin 2:5.10
Pin 3:0.00
Pin 4:0.26
Pin 5:2.17
Pin 6:3.52
Pin 7:2.17
Pin 8:4.82
Pin 9:5.69
Pin 10:0.17
Pin 11:5.96
Pin 12:0.00
Pin 13.13.56
Pin 14:5.88
Pin 15:13.28
Pin 16:5.10
Here is what I get on the gate pads for the fets with them loaded with a 0.1 uf cap . Scope set to 5us 5volts/div
With pin 10 in circuit
Pin 1:0.00
Pin 2:5.10
Pin 3:0.00
Pin 4:0.26
Pin 5:2.16
Pin 6:3.48
Pin 7:2.16
Pin 8:0.51
Pin 9:5.73
Pin 10:4.05
Pin 11:0.00
Pin 12:0.00
Pin 13:13.77
Pin 14:0.00
Pin 15:13.77
Pin 16:5.10
And no drive signal amp won’t power up .
I noticed pin 10 goes to a resistor and the other side of that resistor goes to pin 2 of the ic
