Heys guys ....
I have a Mmats 3000.1 mono block amp(new version) that I got in for repair ,(cutting off or triping ) problem is it plays sound good at 10-20 amps off current but as soon as we increase the gain an the current reaches 30Amps the amp would trip off power light flashes ..an their's sound again , some times it holds out for a min an some times it cuts off sooner , all voltages checks out so far ,rail voltage is 79.89 volts an the caps are standard 80volts , I scoped the amplifier's output their does not seem to be any clipping .....
... Has any one worked on this problem or this type off amp before , or have any clue's as to what might be causing this problem ?
