Looks pretty simple. Why don't you build it and tell us if it is any good.
Trust your ears, mind and heart. If it sounds good (and has low DC offset and no oscillation) it is good.
And regulate the power supply.
Aud_mot
Aud_mot
'Trust your ears, mind and heart. If it sounds good (and has low DC offset and no oscillation) it is good. '
Interesting advice here from AUD_MUT.......i am afraid i would have to disagree....profoundly.....it will probably sound excellent if you've built it yourself, and have nothing else to compare it with...
If prescription spectacles. aircraft wings, the combustion engine...etc were designed in this fashion the industrial revolution would still be a VERY distant gleam in mankinds collective eye......😱
Aud_Mot said:Trust your ears, mind and heart. If it sounds good it is good.
I like your sentiment... enjoyment of the music be the goal...
i have one similar: Trust your ears, listen, practice often
dave
These are simple enough circuits you can build 'em up and play around all you want. It would be interesting to compare your circuit with another simple preamp like the "DoZ preamp" -
project 37 at www.sound.au.com.
If you looking for minimalist preamp, I always liked that one: http://www.metaxas.com/pages/masnewfiles/index.html
I didn't build it, but since it's coming from Kostas Mataxa, you can only expect good things about it.😉
Peter Daniel said:If you looking for minimalist preamp, I always liked that one: http://www.metaxas.com/pages/masnewfiles/index.html
I think you may have been snafued by frames... that URL takes you to the metaxis home page. I'm having trouble finding what you are referring to.
dave
Peter Daniel said:Looks like one link for all pages. Choose DIY from menu and see CP3 preamp.😉
That is how a lot of framed sites work. You can often transmit a URL that doesn't take people to where you want. It is usually possible to grab the URL of the frame (control-key contextual menus on a Mac - "open frame in new window", on a PC i don't know). Here is the URL of the frame:
http://www.metaxas.com/pages/technology/diy.html
dave
- :: minimalist solid state preamplifier ::
