Miller Cap: C0G, Mica or Polystyren?
My experience is that the inexpensive polystyrene capacitors available today are nowhere near as good as the old ones that are only available in limited old stock values.
The C0G types may actually have a voltage coefficient even thought they do not have a temperature one, so they can change value slightly if the applied DC voltage varies.
I do have a nice assortment of Mica capacitors, but when using them for some reason that I have not yet found they just don't seem to be a favorite.
I tend towards Rel-Cap which makes polystyrene and foil capacitors and Teflon/foil ones. Naturally they are ridiculously expensive.
Subjectively, I've only compared ng0/cog with silver-mica in a Class AB amplifier; it was a sighted comparison although at the time I felt it was a comparison made without expectation bias - except perhaps that I should hear no difference. I heard a very small subjective difference, the ng0 sounded cleaner, without any artifacts I could detect whereas the mica had some slight haze / micro texture (forgive the b-s adjectives) to the mid-treble. Of course, there are tolerances with these caps and although they were both marked at the same value I have also found, subjectively, that the value of Cdom can have a clear impact on the sound.
I always choose ng0/cog for my builds unless wanting to use something else because I am trying to clone a particular design as faithfully as possible. I use both SMD and through-hole ng0/cog.
I've never tried Teflon, PIO etc. - generally I prefer small physical size for tight pcb layout around the VAS device.
If the value varies with DC excitation, it also means that it changes with <large>* AC levels.
In filters, Cdom or similar roles, it will cause odd-order distortions if the effect is polarity-independent, or even-order ones if the effect is asymetrical.
That is exactly the reason why I said these caps were objectively inferior compared to high-quality plastics: the dielectric absorption of, say mica might look horrendous, but in fact it remains a (mostly) linear phenomon, meaning it might slightly impact the frequency response; by contrast, anything that is amplitude-related will ultimately result in THD increase.
*the definition of large depends on the actual signal level compared to the voltage rating of the cap, and also on the level of tolerated non-linearity: for ppm levels, a COG should be safe.
If your target is in the ppb range, that will no longer be the case, and Cdom will typically see the full output voltage, making things worse.
At this level, the PCB material and many other factors will also come into play, so the capacitor could only play a minor role in the final THD result
BtW, poor standards PS caps are not a new thing: Suflex for example managed to do it wrong in the seventies.
I do not know how they achieved it: after all, putting together a good plastic film, foil and termination doesn't seem insurmountable, and manufacturers (mostly German) did it right 20 years earlier, but somehow they missed it.
No wonder they disappeared from the manufacturing landscape...
I don't think so: high quality films, like PS, PTFE, PE are probably the best after vacuum caps, but it is difficult to be definitive about ceramics, because so much depends on the exact process, impurities, etc. when you look into really fine details
I am almost sure that "in average" present C0G is better or much better than any film.
For example - C0G gives the very best performance in low-distortion oscillators. It means a lot to me (as I am now mostly measurement equipment DIY-er).
A quick search indicates that calcium zirconate C0G have almost zero voltage coefficient of capacitance.
http://www.kemet.com/Lists/Technica... Class-I C0G MLCC and SMD Film Capacitors.pdf
They are used in equipment that measures better than an AP can measure. I highly doubt this is the issue that Ed makes it out to be.
