Mica and Goop
Having read this entire thread, as I'm about to embark on my first Class A amp - A Pass F5, am I right in concluding that my choices for 4 tiny devices on 2 massive heatsinks should be:
Keratherm with no paste:
Wärmeleitfolie Keratherm® - Rot 86/82 Kerafol 86/82 (L x B) 190 mm x 190 mm Stärke 0.25 mm 6.5 W/mK im Conrad Online Shop | 189058
Berylium oxide (also very good, but toxic if powdered) with silicon grease.
Aluminium Oxide with silicon grease.
Mica and silicon grease.
- I have polished my mosfets
- I have polished my sinks (Conrad MF35 - 151.5)
- I have Mica, ranging from 0.1mm to 0.02mm, but I'd prefer something more effective as it makes such a big difference for the small outlay.
Thanks in advance.
Thanks Andrew. It came in at 0.1mm thickness, but certain pieces delaminate quite cleanly to reveal much thinner slices. I am a tad worried that such thin pieces might be vulnerable to shorting, and as I'm building an F5 with no thermal protection or current limiting, I guess that's all the more reason to make doubly sure I have excellent heat dissipation and protection from all kinds of short circuit.
Wouldn't Keratherm be worth the modest investment, in your view?
Well, 1973 Celestion 44s with £30 Seas tweeters and rebuilt Xovers. Drivers replaceable for £100 for a full set, I should think. I may well take my chances with nothing at all. I will be using Neutrik connectors to defend against short circuit, and I'll be careful to fine tune the DC offset. Thanks for your concern though. You certainly do talk sense.
Mica and Crystal also go beautiful together.
I know Silpads and Phase Linear amps don't make nice music, causes them to oscillate. In fact it's the service manual to remove them if you come across them. I tried Silpads on an old Quatre amp ( NOT the Gain Cell model) and had all kinds of problems, put good old mica and goop back in and the problems went away. Both those amps use TO-3 xsistors.
Craig
Tell me, since I've become OCD obsessed with delaminating 0.1mm mica washers into thinner pieces with a scalpel: is undamaged 0.01mm of mica (one hundredth of a mm) capable of insulating mosfets at ±45 degrees for years without degradation and failure, or should I go a tad thicker? What thickness do you all use? I'm figuring that this element of a class a amp is easily as vital as any fancy component choice.
