Mica and Goop
Hi bwaslo,
Just a data point for mica and goop would be nice. The mica is the universal constant everyone has. I'd be interested in how much the exotic insulator buys you.
I still use mica and goop. It works and I have the materials on hand.
Hey Andrew,
Do you have any idea how much work that would be. Even asking for one other is a fair amount of extra work for bwaslo.
-Chris
Hi bwaslo,
This ought to be interesting.
The torque applied to the mounting screws is important. Doing them too tight will increase thermal resistance.
Hi labjr,
Mica peels in layers. If one is careful, the surface will be as smooth as an insulator before splitting. This is something I do not do as a rule.
-Chris
I use mica a lot, but I only install thin mica.
I aim for less than 2thou (2mil) and often get around 1thou.
Many of the mica pre-cut isolators are around 6thou thick and I can get two, or three, thin isolators from each. Occasionally a layer breaks, or slices out, part way across, these small pieces become To220, or if very small To126 isolators.
I have to use strong glasses just to read resistor colour codes and solder where I actually want the joint.
I also use a magnifying lamp with the 3.5dioptre spectacles, when I need to see more of the small details, like soldering 603 smd caps/resistors to very fine tracks.
That combination let's me see the coloured fringes (Newton's rings) when I start to split a mica sheet.
The two difficult operations (at least for me) are getting the knife to "Start" at roughly half thickness. The second is getting the split to travel slowly and controlled all the way past a pre-punched hole. If a sheet is going to break it is usually at a hole.
The knife/scalpel has to be sharp. I use a diamond chisel sharpening "stone", grade 150 for reshaping, grade 300 for sharpening and grade 450 for very fine sharpening. My old hobby knife from about 45years ago still has it's second blade in it (it is getting quite short and won't last another decade). I lost track of all the spare blades about 40years ago.
Scalpel blades are brittle. They will not accept abuse.
A micrometer is needed to see if the thin mica is tapered. Micrometers can read down to <0.5thou and some to 0.1thou.
You can get away with a caliper that reads to 0.01mm for general thickness measurement.
I bought a digital caliper a few years ago and it has been a good workhorse. It reads down to 0.5thou, or switches to 0.01mm.
It can measure depth, or step, or diameter, or bore, or thickness.
I wish I had it when I was manufacturing my car.
yes, the conversion is 1inch = 25.4mm
it was the thou that got him,
1thou = one thousandth part of one inch.
and the North Americans call it a mil, presumably because they think mil equals milli, again a one thousandths part of one.
But I did give two other references that linked thou to USA/Canada and metric values.
He just did not read.
I am good at swapping back and forth between feet and metres and inches and millimeters and even from miles to kilometres. in either direction and virtually instantly.
But one I have not got used to is from thou to 0.01mm and back. I always have to think about this especially when on the lathe and have to divide by two to ensure I don't take off too much.
Yes, my cross feed read in thou of cut and that removes 0.0508mm from the diameter.
And when I am trying to work with something around 74.35mm diameter with an old head on my shoulders and an old imperial lathe that had a run out of ~1thou per 9inches of bed travel ???? I had to be alert to avoid mistakes.
