metals!
Disabled Account
Joined 2010
Just for interest!
I know that everyone will sigh!
However I wondered what people think with regards the questions:
Linked to "I will believe it if I can measure it!"
I would like to ask what people think regards
1. Solder containing silver as or opposed to lead tin Etc
Which is the preferred %?
2. The cable question, silver plated PTFE or Teflon insulated as opposed to copper linear crystal / oxygen free copper.
Can you measure a difference in sound?
If not why not?
M. Gregg
Any time two dissimilar metals come in contact a galvatnic and thermonic junction is formed. Above 0 absolute it will produce noise.
With regards to cable, given sufficiently precise equipment, I'm sure you can measure a difference.
The resistance will be different, the capacitance will be different, the characteristic impedance will be different.
These will all impact how the cable interacts with the output and input it is connected to.
Whether or not it makes a difference in the sound that is produced is another matter, which is very subjective.
I use 60/40 rosincore and good quality wire.
I know that cables can be directional.
That skin effect seems to alter "frequency response"
Diameter seems to also have an effect.
Dielectric also has an effect on "sound" this is the case with caps PIO, polypropylene etc.
The number of crystals and impurities can change "perceived sound".
When I tried some solder from "Audio Note" the sound seemed different when I ran out and used a silver mix!
Can this be measured?
Or are we fooling ourselves if it can’t be measured?
These comments are here for criticism!
I am told that the junction between two metals creates a thermocouple. This has an effect on signals. This is why "High Quality" cables use a welding connection method so the metals "mix" to reduce this effect.
The impurities between the crystals of a cable also has the same effect and can make a cable directional.
So if we wire with lead it would be heavy
If we wire in silver it would be bright.
LOL however is there any truth in this!
The silver wire would be brighter and lighter
The lead wire would be duller and heavier
In my youth we didn't as a rule have HiFi separates, things were integrated. Then came separates. Having phono cables became a necessary evil to attache everything together and certainly wasn't seen as a step forward in itself. Now they are a fashion item.
I use non-ROHS 60/40 lead/tin solder, because it melts at a lower temperature than lead-free
