Meridian 101 pre amp needs new power amp
Joined 2006
Variac said:
Now Ricardo we DID ask you to cut your siglines down to three line maximum, as that is the policy here.
Hi Mark
I did not get scared with Andrewá comments.... I am always willing to learn more... It makes sence that replacing psu caps can not alter freq response....;)
Now I do not want to break any rules here so could you explain what you mean by posting only three lines ?
Ricardo
Joined 2006
Gordy said:
Your pre-amp...
1) raises 120mV to 775mV and hence has a gain of x 6.5 . (Note that 775mV is a standard reference level in the professional audio industry, and hence this is why the Meridian is specified reference this level).
2) has a maximum output of +20dBm which is (if I recall accurately) 7.75 V across 600 Ohms.
The Rotel RB 06 and Audiolab 8000P require about 1 V for full output, so you should have no problem with driving them from your pre-amp.
Both of these amps seem to work well at their price points.
Hi Gordy
Following the general ideas from this thread I decided to upgrade the Meridian instead of replacing the power amp.
I already recaped the 103 psu, made a dedicated direct Mains cord and started to mod the 101b pre.
In this case I replaced the regulators and rectifier by a 317/337 / hexfred setup and recaped the psu.
In the output module, I have replaced the stock opamp by a LM4562.
Now I would like to replace this opamp by a buffer stage. (Pedja...)
As I am a bit confused about the idea (a buffer should be used to couple between different impedances)
My big question is:
Do I need a gain of x 6.5 on this buffer ?
Ricardo
Joined 2006
AndrewT said:
you should be able to decipher the resistors on the input & output pins to determine the gain currently set up through the opamp.
Then arrange for either a 0dB buffer or +xdB discrete gain stage to fit the opamp pins.
Hi Andrew
So you mean I can replace the LM4562 by a pedja buffer (o gain) once I figure the pin layout ?
Joined 2006
Well I know this opamp is arranged to have x6.5 gain.
I could replace it by a better opamp (like the new metal can available) but I know that a discrete design is much better, particularly if it is built with jfets and no feedback.
So I decided to build a pedja but I am afraid this kind of buffer is a pure voltage follower (0 gain).
Can the pedja be modified to have some gain ?
Ricardo
Joined 2006
Hi Lee
With my present RIAA, I need this gain, otherwise the sound would be too low.
With the CDP, I really have too much gain so maybe I could do with the buffer.
How does the output from Salas RIAA compare to the CDP on your setup ?
Ricardo
Joined 2006
Your pre-amp...
Hi Gordy
It may seem strange to get back here, but I understand you have acces to Meridian info.
I replaced the 101 pre by a buffer (DCB1) with great results.
Now I would like to know how to determine the Meridian 103 power amp gain based on it´s specs:
Output: 35W/ch in 8ohm
input: odBm (775mV) over 10k for 35W (Does it mean the input impedance is 10k?)
Joined 2006
After a long search for suitable transformers I found the FEAS 26V 250VA.
Due to sme T$me constraints I could only buy two and as these have single 26v secondaries, I could not implement a true double mono setup, so I used them in series to feed dual rectifiers as in the schematic.
Joined 2006
So far so good.... sound is much more open and detailed with the new setup.... but I am having trouble at power on. My house has an old electrical instalation that can not withstand too much inrush current.
Every time I power the new psu and have other appliances running, the mainsboard fuses trigger.
How can I limit inrush current during power on ?
