Measuring Surround of passive radiator.
Hello TBTL,
Thank you for your Reply, i tried this test quicky using the mic of laptop i would hold hand in the air in the name of physics if this worked. this is what i got.
BR
Mmm, it appears this one has quite a lot of damping. Too bad, then this technique doesn't work anymore.:( There is not much of the expected ringing.
If you really need a number and you can live with it being inaccurate, something like 130 Hz seems to be the lowest frequency you measured.
Hello ,
i created this setup using a Sauter digital dynamometer and a screw with of 1mm pitch.
BR
  • ^6C142116CBABE9126A8C257A25928B4C165921AE4DB978DC26^pimgpsh_fullsize_distr.jpg
  • ^8D2BE82DDC493C441F65B0604B3F703BEA2EAC46A64CB6E0FE^pimgpsh_fullsize_distr.jpg
