I'm not sure how to phrase this.
Is there a limit to the size of the signal that the grid can handle?
I had an idea to replace two 12ax7 gain stages with three 12au7 gain stages.
I figured 100x100 equals 10,000
And
20x20x20= 8,000
Which is about what I want - I think - but I'm not sure.
I'm trying to clean up a 5f1 circuit but I don't want to make it wimpy. I have an extra triode available (another story) and it seems like a good theory. But when the signal hits the tone stack it will be 20x20=400x, as opposed to the 100x of the typical Fender circuit. I'm afraid that hitting the grid of the last triodes with a big signal will create distortion.
If I had to guess - I'd guess that the B+ value has something to do with this?
And
20x20x20= 8,000
The max signal you can put on a triode grid before significant distortion sets in depends on the bias and the circuit, but for a very rough estimate take the supply rail voltage (B+/HT) and divide by twice the valve mu. The max signal before damaging the valve will be higher, maybe a few tens of volts.
- Live Sound
- Instruments and Amps
- Max grid values
