There are so many Dac options, it depends what your budget is.
Here's one you might like to consider ...
http://www.audio-magus.com/product_p/am707.htm
or
http://www.obadimports.com/catalog/item/4377355/6829249.htm
You can find dacs on ebay, but make sure you get an optical input on it.
or
Hi brent i would love to do some mods on my 67 but not sure were to start or what components i kneed,What i want is more detail which component change would give me the bigest upgrade for the price i cant realy afford a lot of money so it would have to be done in bits.What differance would changeing the oppamps give me
Over the original opamps the detail change would be pretty big. We always use LM4562 (LME49720) with some rubycon za caps on the power rails.
Simple upgrade and it will impress you. Once thats all in you can bypass the HDAM + muting section so the audio runs direct from opamps to the sockets. This allows you to hear the opamps properly.
As you go along there are lots of little tweaks you can do
Brent
Brent
Hi again mate i am not realy electronic minded but i can use a soldering iron so im gona give it a go.Were is best place to get oppamps from and do you just solder them in or use a dil sorry to be hard work but im new to this hifi moding.Just got an amp 6 it sounds really well but think the cd player is showing its limitations
Hi
I have to be careful here
as I do sell the opamps. You can link to my site below.
Dil sockets are good for swapping different opamps in and out. Other than that solder then straight in. When you get your bits I will be only too happy to point you in the direction of HDAM bypass etc
Brent
![angel :angel: :angel:](https://files.diyaudio.com/forums/images/smilies/angel.gif)
Brent
The treble should be much more controlled rather than in your face. For most upgrades I use a good quality copper wire (poor silver can make treble harsh) like Kimber. So if you have some speaker wire thats thin enough to use try it even better would be a bit of interconnect wire , the wire here makes very little difference so don't worry too much about what to use.
Brent
Brent
Damping does make a difference yes, especially as the costs are low.
Marantz are not usually aggressive no. Do you use any silver plated wire in your system? If so swap it with some cheaper lead and see if the treble calms down to eliminate.
Also any mods you do need a good few days to settle down.
Brent
Brent
No mate no silver wire i have a 41HZ AMP 6 MARANTZ CD 67 THROUGH SOME MISSION M70I SPEAKERS the phono lead conecting cd to amp is a realy stiff thick one looks good quality but dont know what make it is. It sounds ok when there not much going on in the music but when the the music gets busy it seems to get confused edgy IF YOU KNOW WHAT I MEAN but the detail is brilliant with the 41hz amp i have had some amps over last 20 years NAIM MUSICAL FIDELITY . QUAD MARANTZ but this amp is the best i have had
- Digital Source
- marrantz diy dac
