Mark Audio Alpair 12P with current drive
Then yes, play with them. You might need to use them as midYweeters to keep the load off them. Add a couple woofers and XO as high as you can while keeping close to ¼ wavelength C-C. Use them for load and heavy.
Puzzlekoat wa the brandname i started out with in the late 70s, it is kool so i just use it for a generic name. ModPodge is fairly common brand, I have tried a couple others they all work very similar, but usually come at different consistencies. I like using the semi-gloss.
https://www.t-linespeakers.org/design/tweeks.html
dave
Wilco
