Mark Audio A12P SuperPensil Buildlog
I will use this post as a log for the entire build of my SuperPensils.
Resources
Plywood Tips
Tools
Measurement
Materials
Other Materials
Binding Posts
Speaker Cables
Total Materials Cost: $463.69
Cut Plan
These are the cuts to be made at the hardware/lumber store for transport. The images depict the layout of the pieces on each sheet.
Sheet #1
  • 37"
  • 37"
  • 9"
  • 9"
Sheet #2
  • 35 1/2"
  • 35 1/2"
Dimensions
Top & Bottom:
18 3/8” x 9” (4x)
Sides:
18 3/8” x 37” (4x)
Back:
9” x 35 1/2” (2x)
Front:
9” x 33” (2x)
Center Brace:
16 7/8” x 35 1/2” (2x)
Right Brace:
4 1/2” x 21 5/16” (2x)
Left Brace:
3 3/4” x 21 5/16” (2x)
We use single strands from solid core CAT 5 cable. Preferably plenum grade with teflon insulation.
We use posts with much less metal in them. They are actually hard to find because i guess they look too cheesy to sell via pictures. We order them 200 at a time to get them. Neither Madisound or PE have them. PE has something with the same posts, they do not fit our requirement that the posts don't stick oit (where they can easily be crunched)
Gold Plated Banana 5-Way Speaker Terminal 260-302
These are the same posts but the cup requires a larget hole (we only need 2" holes. harder to get your finders in, but less of the panel isremoved to mount them.
High Power Terminal with Fuse Holder 260-293
dave
Planet10,
I use solid core wire from home security system wiring which is 4 conductor 22 awg, and I thought that is small so I double two wires ea. I think the 22 awg can handle about 1 amp over typical distances for speakers. Cat5 is 24 awg, even smaller. You like having some resistance in your wires for audio quality?
Btw, the binding posts you show above are the same as what I use except my are nickel plated. I like them.
So couple of tips, never have the pieces cut at Lowes. I have been working on getting it square all day. The good news is I am succeeding. The speakers will be 36 3/4" tall, so I list about 1/4" of height in the process.
Final conclusion, I need all of the tools. 🙂
I use a table saw with a sled. But here's a young man who knows how to get good cuts with a circular saw. RIP GUIDE FOR A SKILL SAW - YouTube
Don't forget that only some of the pieces need to be exact, the overlapping pieces can be left oversize and trimmed with the router.
Never assume that factory edges are really straight. If you want to check it at the store, go use one of their big levels.
Keep it square, measure the diagonals.
Most of all... Have Fun. (and be careful of those fingers)
The larger circular saw was much much better at getting straight cuts compared to a Rockwell VersaCut I had laying around.
I think a custom jig made out of plywood and hardboard is a good alternative to purchasing a sub-par jobsite table saw. A table saw is only as square as the piece that is touching the fence. In order for a table saw to be accurate, you would need a jointer as well. At least the faces of the plywood are flat. 🙂
Updated the Materials post with some better items. Will add some more options for cables and binding posts as well. I want this to be as complete as possible.
Lots of good info about the Mark Audio A12P drivers that I didn't know when I got started.
ITSTV Makita SP6000K Plunge Cut Circular Saw - YouTube
I got one of the Makita track saw in addition to already having a circular saw metal jig with bearings that rides along a 2"x2" L angle track, a job-site tabs saw, and a sliding compound mitre saw.
My A12P build got postponed and i've yet to use the Makita track saw. The older jig is good at cutting perfectly straight but the circular saw i attached to it isn't so good at getting a perfect right angle cut. I'm hoping the smaller diameter blade of the track saw will be better setup for right angles. My Hitachi contractors table saw isn't a bad one but i still have trouble getting a perfect 90º angle cut. The 10" Dewalt sliding compound mitre saw does perfect cross cuts up to ~12" across.
If happen to be located near Philly, i may be able to help you out.
