Marantz PM75 DC Offset
You cannot fix the "problem" since it is a result of the circuit design.
Perhaps the op amp in question has degraded and has more input current than it originally had,
and no longer meets the specs for the part. You could try another new, unused sample of the same part and see.
Semiconductors can change their characteristics over time, for various reasons.
Some new parts in DIP packages must even be "baked" in order to meet their specs after long storage times,
like carbon comp resistors, and for similar reasons.
Try the 6,8M resistor as suggested (probably the easiest way), or use low input bias current OPAmp like OPA134 (may bring sound improvement as well).
The offset nulling is also a valid solution - you can leave the 10pF capacitor in place.
Or, ignore the offset... it is not that bad. Do one of the above if it gets above 100mV.
Compensation cap (10pF as said) must be at pins 5 and 8. Bal trimpot between 1 and 8. So effectively the pin 8 is common to both.
I dont get whats happened to orignal design. My aim is to not really get it to 0mv but get it to the correct 60mv output. If its a case of replacing the opamp with new ones then thats a lot easier to be fair as I have no idea how all these fixes will affect the sound.
so far I got
1), 6.8M across the negative and pin2 input of opamp
2) trim pot between across pins 1 and 8 of opamp (but what value? and trims has 3 legs, short 2 toegther?)
Looking at it if sound quality is not affected then 6.8m seems easiest and best!
I'm open to other ideas and really greatful for all the help given!!
