What can I do with this?
http://cgi.ebay.com/Marantz-HDAM-Mo...0?hash=item19b503c961&_trksid=p3286.m20.l1116
That would depend on what you had in mind.
As a CD player buffer, it is probably not the best solution.
If you check out the CD63/67 mods thread, the best thing to do with the HDAM is bypass it !!
Andy
Andy
from ebay:
"Q: is it the PCB only or also the other components too? is it stereo or mono? thanks Federico
A: The item include PCB.Thanks."
What du you make out of that? Is it pcb only or a complete kit with all the parts?
Regards Håkan
Regards Håkan
h@kan said:from ebay:
Regards Håkan
It says stereo in the listing and also that it includes high quality parts (ie nichicon muse, etc), so I would guess it has all parts. Not bad on the face of it for $30, but what can be done with it?
UH ohh,
I think that's for the pcb only, There is another listing with complete parts for $99.90= http://cgi.ebay.com/Marantz-HDAM-Mo...ash=item19b503c782&_trksid=p4634.c0.m14.l1262
Or you can bid on this http://cgi.ebay.com/Marantz-HDAM-Mo...ash=item1c0bebb68c&_trksid=p4634.c0.m14.l1262 I think it's got complete parts, But you can always ask the seller.
FYI, I recently won a bid form that seller for a precision power regulator kit that has a buy it now price of $99.90, I won it for $34- and paid for it, I have yet to received the kit though, maybe next week.http://cgi.ebay.com/SPEEDO-MK2-Regu...ash=item1c08f21294&_trksid=p4634.c0.m14.l1262
"but what can be done with it?"
YOu can put it in one of these chasishttp://www.thlaudio.com/indexE.htm , add a cocktail of volume control , input selector, power supply and your choice of connectors . you got yourself a high end preamp.
FYI again, I just asked the seller how much the top most chassis is, It cost around $160- usd.
Well Known Bad Seller
OT
I hope you receive thisitem.
The seller is well-known for not sending items and refusing to refund etc. there are several threads on this forum about Tzeng Albert.
Andy
marchel said:.....................
OT
Andy
WARNING WARNING
1. This seller is a well-known scam artist so purchase is not recommended.
2. Look carefully !! The listing above is for the PCB only. No components are included. LOOK CAREFULLY!!
This is typical of his listings.
His components are not always genuine.
Do a Search for the seller to find warning threads.
Be warned.
Andy
PS Sorry for not posting the warning earlier. Wrong time of day for me.
DreadPirate said:What can I do with this?
Be warned.
Andy
Ahhh, Thanks,
But anyway, I will keep you updated when(And if 🙂 I received the regulator, in this thread, I will let you see whether the components are genuine or fake.
Another good example of a Chinese company ripping off the Western market by stealing their designs.
Marantz HDAM is just a discrete op-amp built with several jfets. The schematic for one is in any Marantz amp service manual that makes use of them.
Do NOT give these people your money. Make it yourself on stripboard if you want to try it out.
I am of course mistaken here, it says listing is for pcb only.
I hate this kind of contradictive description of the item.
He states that:
"The item is PCB of the Marantz HDAM Module Preamplifier DIY KIT."
And also: " Audio Grade Hi-End Components NICHICON / RIFA / VISHAY-DALE / HOLCO"
This is NOT how to describe an item, it creates confusion.
And on a straight yes or no question:
"Q: is it the PCB only or also the other components too? is it stereo or mono? thanks Federico"
He answers this bs:
"A: The item include PCB.Thanks."
How can this guy have 100% positive feedback?
I could be mistaken but I have a bad feeling about this seller.
Regards Håkan
He states that:
He answers this bs:
Regards Håkan
Original discrete HDAM opamp from Marantz has 8 transistors or 9, if one of them is wired as diode in current mirror below folded cascode VAS transistors...but I can only count 6 per channel. That being said, this scam is obviously not based on original schematic...but it can be HDAM-S1 or HDAM-S2 buffer module, not preamplifier as stated. Don't buy it.
The circuit for this 'HDAM' module has been posted here before and as commented bears no resemblance to the Marantz version.
http://www.diyzone.net/images2/HDAM_BUFFER_SCH.pdf
Andy
Andy
I would think this circuit, which is a x1 diamond buffer circuit (and NOTHING like the Marantz HDAM circuit) would sound better than a HDAM, which I consider to be a piece of over engineered, over complex junk, and gets bypassed in every Marantz CD and SACD player we get in for Upgrade work.
But as it's only x1, with no way of adding gain, it can't be used as a "preamp", at least not in my definition of a preamp.
Regards, Allen (vacuum State0
HI,
I'm here to give you an update (as promised) on my regulator, I ordered from Albert tseng.
I already received the kit, Assembled it this morning and tested it just now, It works perfectly.
I will post picture later , as soon as I can. You be the judge , Whether the component are fake or not. All i know is that the kit outputs +/-15V dc that I required.
You got a regulator, but this thread is about a rippoff HDAM module.
What's the connection?
Regards, Allen (Vacuum State)
Just read post 7 8 9 10.
BTW, Sorry Allen for the OT, BUt I don't feel the need to make another thread just to show that I received the item.
- Analog Line Level
- Marantz HDAM Preamp DIY Kit on Ebay
