Marantz Cd84
Hi Elso,
I have read on your KWAK-CLOCK-text.doc this:
"The KWAK-CLOCK will work with any crystal in the range 8 to 24.576 MHz." but Marantz cd-84 had crystal 4 MHz.
It is possible mod your Clock for work at 4MHz?
Bye
Andrea
drews said:
Hi Elso,
Bye
Andrea
Hi Andrea, In fact it will work with the 4MHz crystal but it will not do any good as this clock is probably for system control (U COM). You need to replace the clock feeding the decoder and/or servoproccessor 😎
Hi Elso,
I have chech now the service manual.
The cd-84 have another crystal on U-COM Servo but the frequency clock is 3,58MHz.
I don't understand your advice.
Sorry, please explain better the question because I don't understand .
Andrea
And here the other crystal on SAA7000
Bye
Andrea
Sorry Elso,
here you can see the picture that was on zip file.
No, The KWAK-CLOCK will work perfectly with a 4MHz crystal. Even tried 2MHz
These is a great news. Is it necessary do some mods for improve the 4MHz crystal, or just use this crystal on KWAK clock 7?
Thanks a lot
Bye
Andrea
drews said:
Sorry Elso,
Thanks a lot
Bye
Andrea
Hi Andrea,
No mods needed for the 4MHz crystal.
Picture is not legible. Please use GIF files for schematics. You can use Irfanview for converting files and resizing to make it fit to the forum.
www.irfanview.com
drews said:
Sorry Elso,
Thanks a lot
Bye
Andrea
Hi Andrea,
did you change the clock in your CD84 ? if so what was your experience ?
many thanks
