RCruz said:Cool pic... what image editor did you use ?
I bet it was FIREWORKS!
6h5c said:You are mean Brent, rubbing it in like that
But, after all, you are one of the 'fixers'
While I have his cdp I can extract the urine as much as possible
Brent
Brent
And fit upgrades
Hi LeeThomo said:Ricardo, that psu will be perfect for the discrete stage.
You've got mail about those Mundorf caps, btw.
have you received my e-mail ?
Re: On a KI TX what leads go where?
I have a Marantz PDF somewhere, that shows all the differences between the OSE/Ki etc. I'll dig it up and post it as soon as i'm home, it can be very handy.
Ray
magilla said:One got loose( yellow with 2 cores), and fixing that made a couple more come loose. Is there a list of which colour to which pad?
Ray
I was just looking at this Tenzing 2 modification package by Audiocom.
They do away with the HDAM but replace it with transformers. The analogue filter is the same, (op-amps changed), so what is the need for transformers? The o/p of the second op-amp is unbalanced and has negligible offset.
I don't see the point unless I'm missing something.
I'm pretty sure these guys are reading our big thread too:
"The stock CD63 uses HDAM modules and capacitor coupling for the analogue output stage. This area of the CD63 creates a bottleneck in the sound and seriously degrades the output filtered output from the active op-amp stage, masking, veiling sound, reducing detailing, dynamics and realism. "
Exactly the sorts of things we've been saying on here, and now they've started to remove the HDAM too.
Simon
Simon
rowemeister said:You can get the BR or GR version of this FET with the GR version being slightly better. I believe they are selected for their tolorence from the BR batch. I'm sure someone can correct me if i'm wrong.
Brent
Don't know if there's a BR?, according to data sheet
Simon - I don't think so, that particular package is basically unchanged in over 7years: the CD63 has been around a long time.I'm pretty sure these guys are reading our big thread too
I tried transformers amid a bunch of other weird stuff, once upon a time. Not good for what I wanted.
- Digital Source
- Marantz CD63 & CD67 mods list
