This is the Audiocom Super-regulator. As the name implies it's not bad. The SPower is fractionally bigger (due to the output FET), and is thought to be superior-sounding. Certainly the SPower can supply much more current and doesn't sag under tough loads. I use some of each and have never directly compared (there's not much point for me as there are still 7805s to be replaced in my machine). Even this reg is night and day over a 7805
Just working out how to install it without removing the PCB lol!
Simon
Simon
RCruz said:Where are you putting it ?
DAC digital, otherwise known as Pin 16 or DVDD. Previously a 7805 fed this pin, directly through the hole left by the long-gone power supply resistor RD04.
To upgrade the reg without removing the PCB (and hence making it go breaky) I weakened the legs and rocked it till it snapped off. I then soldered to the leftovers...
I tested the reg first with a comical rig of wiring and electronic junk all over my bed... so tonight I may be sleeping with my CD63, or just little pieces of solder and strands of copper!
Anyway, it's in and playing
Simon
Hi Ray, thanks for the answer and great little circuit, what I did is what you wrote, adjusted the pot so that DC on 2 = DC on 3rd pin. Since I have parts for another one I consider putting it to the DAC of my receiver or to servo clock, well, I'll see, right now I enjoy the new sound.
Greetings,
P.
Greetings,
P.
Bold move Simon.
Simon
Course, that method does have a tendancy to rock the pads loose on the other side.
Andy
rowemeister said:And maybe cause a short and make the cdp smoke and not play anymore.....
Brent
Well it was damned fine and dandy till I put the flipping lid back on!!!!
So that's where you went wrong mate!!
Jim
Now what ?
Hope it is still playing... I hate this suspence.
SimontY said:Well it was damned fine and dandy till I put the flipping lid back on!!!!
And that's what separates the boys from the men...
- Digital Source
- Marantz CD63 & CD67 mods list
