the only advantage for Brent in having a CD67, is that there is more room for more / bigger transformers
SimontY said:
I'm still waiting to get criminal injuries compo for some chav biting part of my ear off, then I'll do some upgrades!
Start a new thread, please, if you are going to discuss your sex life !!
poynton said:Start a new thread, please, if you are going to discuss your sex life !!
I bet you don't say that when I see you at UK DIY 2008 and you see it! 😉
poynton said:the only advantage for Brent in having a CD67, is that there is more room for more / bigger transformers
Ahh yes the slightly wider chassis could house bigger VA tx
Brent
rowemeister said:Yes when he walks up to you naked and covered in lube![]()
Wearing nothing but an affection for Diana Krall.
Re. the compo, I wonder if I cam claim my hearing, and therefore hobby, has suffered as a result of my assault...
rowemeister said:No that humming noise has always been there 😀
Brent
Ah well, I'll change that frame transformer VERY soon, for an internal toroid (clock supplies).
Hi Mauromauropenasa said:
The result is a very precise and "natural sound" (because lack the IMD precisely....)
I believe that this is the most serious problem of CD63 MKII Kis, most serious that Jiitter and group delay ....
Just finished the 330pF mod and know what ?? 😀 😀 😀 GRIN
Everything came into place and I can hear music again.
Thank you for your excelent work. !!!
Now I need a little more pace.... Maybe a clock on the servo ?
Ricardo
Mauro's mod
Is Mauro's mod intended to be done instead of the Bessel filter mods or as well as?
JIm
JIm
Ricardo
Or save a few $$$ use a divide-by-2 pcb on the servo. Connect this to your current clock and it divides the 16.9MHz by 2 down to 8.46MHz. A dedicated clock is a little bit better but its also alot more expensive.
Brent
Re: Mauro's mod
No, the 330 pF caps must be installed in the original filter.
And the results is very different from bessel filter, as Mauro did explained above.
Ricardo: it's old, but now you could make this tweak (imho).
http://www.acoustica.org.uk/
Solder the clock on patterns side, and solder the metal can of XO to ground plane.
And put a separate regulator in place of cd04+ for XO.
You could use a lm317, for 5V, with in series output a 10 ohm resistor.
Common soldered on pcb gnd plane.
Ciao
jimh0612 said:Is Mauro's mod intended to be done instead of the Bessel filter mods or as well as?
JIm
Ciao
RCruz said:Now I need a little more pace.... Maybe a clock on the servo ?
That will tighten things up nicely and give immense detail. Brent's product (Servo clock - 8.46Mhz) works well for me and is the only ready-made option at the price I know of:
http://www.audioupgrades.co.uk/clocks.shtml
I can vouch for Brent's products too. They offer fantastic performance and value for money.
Pic of clock on another cd67 with discrete on the main-board for anyone who's interested.
Lee.
Lee.
Re: Re: Mauro's mod
I believe this is the best option... I will be talking to you latter by e-mail.
Thank you Riccardo.. I already have been studiyng this mod but it seems very complicated to me (it involves messing with very sensitive parts and very small ones "SMD".... I am not that good and I can not afford to mess up)
But before I go any of these ways I need a very important advise:
I did the Mauro´s mod with 330pF Polystyrenes.
At the same time (because the modded CD53 is now a bit hard to open "dismantle" any time I need to do a new mod), I replaced the stock ceramic filter caps with 1% silver micas keeping the exact values:
CD21 22 23 24 120p Silver Mica
C601 602 603 604 120p Silver Mica
C607 608 100p Silver Mica
And finally I replaced the opamp output resistors from 47k carbon to a 47k welwin metal film.
The gains in imagery, stage width, instrument defenition and female voice credibility where substantial.
Finally the player seems to be able to play tunes like a normal turntable but I notice a big annoying difference that is always inducing me to lower the volume:
After this mod, I got an annoying presence in the medium to high frequencies so that if a singer shouts, the sound becomes too screetchy.
The voices and instruments are very well defined, articulated and perfectly placed in the stereo picture but I also get this proeminence in the high frequencies that makes string guittars (Steve Vay) to be too nasty and screaming voices (Led Zeppelin) to be almost unbearable.
I would like your comments on the possible causes:
The micas in the filter ?
The metal film resistor in the output of the LM4562NA ?
Or is this due to the better performance now obtained from the opamps ?
Best regards
Ricardo
Best regards
Ricardo
- Digital Source
- Marantz CD63 & CD67 mods list
