Thomo said:BG STD Supply caps, output cap is BG AC 6.8uF. The resistors are all vishay smt's and filter caps are Silver Mica. I agree to the flowing and organic comment. I think maybe I just got used to the more forceful opamp sound.
What do you use for the output psu Simon? At the moment I am still using the SE tx + 2200uF 35v BG FK. Maybe bigger will be better.
Lee.
So you have really nice parts! Perhaps you found no problems with the op-amp sound. For me it was a relief to get rid of it - much more relaxed sound now.
For the output I use the standard +/-20V from the (KI) transformer & schottky diodes. Smoothing is 1000uF/25V BG Std, regs are Sercal S-Power and local decoupling is 220uF/35V Cerafine.
Simon
Lee what you are finding is a very natural sound with the discrete nothing added anywhere. Better regs on the discrete pcb make a large difference (I know you are planning on changing the regs here). Also let the AC run in fora good week or so.
You get a similar effect to what you get by adding a good reg on the dac analogue.
Brent
Brent
rowemeister said:You get a similar effect to what you get by adding a good reg on the dac analogue.
Hmm, I have to disagree here. I think the effect these regs have is quite different to adding one to DAC analogue.
The DAC reg improves the sound in all ways, but really makes it more detailed, warmer, sweeter, nicer! This is a safe upgrade, which doesn't change the character of the player too much.
The output stage regs perform a very different trick: they made mine sound brighter, cleaner, clearer, with vastly sharper transients, particularly noticeable in the treble. The sound certainly opens up! Be cautious about doing this if your system is too bright. This upgrade affects the presentation greatly.
My
Simon
I sort of agree partly with you here. And of course every setup highlights different things.
I was a little brief in any description of the sound between the two. I was refering to the fact that good regs make a large difference in both these areas rather than the actual sound character, sorry for the not so detailed comment that may cause confusion
Brent
Brent
I think Brent is right about the fact that there's nothing being added. I have just examined my speakers, they have a crossover with big gold screws on the front where you can turn up the tweeters and also tweak the treble roll-off. I just raised the roll off freq. and am much happier.
12 inch dual concentric
I am going to fit S-power regs to the output as soon as xmas is over.
Lee.
Lee.
marantz 63/67 mod
Hi Brent, sorry -question from newbie-for Dac analog reg- tap 10V from C813 to input, output of reg onto U199, remove U200, ground to the negative of any cap ? Thanks Quan.
Hi Quan
Best to run the ground to the ground of C813 then input and gnd wires are equal length - unless you are creating a star ground then put it to there
Brent
Brent
Brent, you have had too much influence over my money spending, and today after a 6 hour round trip you spent £500 more of my graduate overdraft. Set them up downstairs in our 'playroom' rather than my tip of a room 😀
They sound sensational, just gobsmacking
And that is with my lowly 75W p/c arcam amp. Im going to pick up the matching power amp which should make them sound even better, as the bass is a little flabby. O and the cd-63 makes a huge difference, when i heard them at the blokes house today through his prototype amp and rubbish denon transport + cheapy DAC they sounded worse than with my setup.
Been listening to them for a few hours now and boy do they show off badly recorded cds. The corrs 'talk on corners' is unlistenable, just flat, lifeless and just plain wrong. But the latest madonna cd sounds better than anything in my collection, new PRIMARY demo cd for sure.
Also love the look of the PSUs on your site, il have to plan when i can afford to get you to do my player after ive been saying the same thing for the last few months. But am moving down to London in Jan to start a new job so need to save my pennies now for a deposit on a flat rental with the mrs.
Listening to some tunes whilst waiting for the big match tonight 😀 😀 (weirdly those are my younger brothers feet, make of it what you will )
So basically you like younger brother feet
Come on HATTON....
LOL
Im glad you can hear how good ATC speakers are and also how well cd63 67 cdp can sound+ £500 for speakers like that is superb. They will be good for another 10 years. Unless you make serious money for even more upgrades.
Brent
Come on HATTON....
LOL
Brent
Ad
You need ....
XRCD dire straites brothers in arms
XRCD jazz at the pawn shop 1 & 2
eric clapton live unplugged
Diana Krall -The girl in the other room
If any of those cds sound poop then you have issues with your system.
Sometimes issues are good, it lets you realise where errors are
Brent
You need ....
Brent
Regarding discrete stages vs. opamps... the discrete stage I built and put in my Rotel just absolutely slays any opamp I ever had in there, including LM4562, LM6172, and AD826. I actually put the AD826s back in before I implemented the discrete because they sounded better than the 4562s. Pic of it in here. If the image doesn't show up, it is here.
I may have to try one of the SRegs on the DAC 5V, but this has been one of the longer periods of no desire to mod it more 😱
rowemeister said:Ad
You need ....
Brent
XRCD ? Well i have a copy of brothers in arms and clapton unplugged will arrive off ebay on mon or tues. Still havent got any krall, but norah jones did sound sublime.
I was lucky with teh stands too as i was talking to the guy on the phone about the new £150 target stands i wanted then he mentioned these old skool fully welded targets he had. Plus they are about 1/2 filled with lead shots too. Not bad for a cheeky £50.
@simon: I can safely say i will not be upgrading speakers for a long long time, i have never heard music sound this good. It was like the step from logitech speakers to my monitor audios !
Poor hatton, the ref didnt help but maywether was just soo accurate with his punches and new how to put off hatton. Bedtime now, followed by bacon sandwich lunch, then music listening day 😀
Hi Guys, good to see the thread is still the Mother of All Threads !
I been away, busy with work and travelling, back on the mod wagon again with the cd63.
Everyone I show or play an XRCD for say whats that ? Well XRCD is Extended Resolution CD, usually 24bit recordings, not sacd, but a recording that sounds way better than the standard recording on 2 channel cd.
I have a few, Sting sounds good with live instruments on XRCD, Havnt got Dire Straits yet on XRCD but guess its gonna be good cos of the guitar ! 🙂
Den
Den
Terrific news Adam! I knew you'd like the ATCs, and they're not bass-shy, something you'd not expect for their size.
Sadly, due to moving back with my parents I'm in a small bedroom and have had to lend out my proper speakers and big subwoofer. The rest is the same, but with Tangent Monitor 6 speakers
So I have a lovely CD63, nice preamp, beefy mono power amps, £80/m speaker cable.... feeding £65 speakers
Ah well, I've never heard cheap speakers sound anything remotely like this!
ImSparticus said:Havnt got Dire Straits yet on XRCD but guess its gonna be good cos of the guitar ! 🙂
Tis good, sounds very clean but nice!
Simon
A little o/t
Hi Simon. Why don't you build something off here? I can recommend the mini-onken. Amazing amount of nice bass for such a small design + fantastic stereo imaging. I couldn't believe the pound/performance.
Lee.
Simon
Lee.
Re: A little o/t
Well my mind has started to wander onto ideas of small kevlar mid/bass drivers and high quality tweeters, in bass-light alignments that could work in my small room.
Thanks for the suggestion - I'll look into the Mini Onken.
Sorry for continued OT
Simon
Lee.
Simon
Dozen of hours has been past over, the sound is denfinitly harsh, and was not with the RJH. I also find it's lacking bass;
is it possible the RJH smoothed the highs/mids and as their volume decreased the bass volume seemed bigger?
And now BG reveal the real highs to be by any means a bit harsh?
Hmm, I've always found BGs to sound smooth and sweet, perhaps even a little coloured (where it all sounds "silky"). Harsh doesn't fit in with my perception of them.
I'd say, yes, you could've unleashed a problem elsewhere
Simon
Simon
I would say the problems are elsewhere. BG offer a much more smooth and musical presentation.
What BG are they and what uF have you used?
Brent
Brent
- Digital Source
- Marantz CD63 & CD67 mods list
