Barry,
How much for the CD63 remote - when I pruchased mine from ebay it didnt have a remote 🙁
Cheers
Cheers
Thinking of upgrading these Caps on the PSU - are the ones above any good or should I spend more - not going to use the analogue RCA ouputs only the digital into external DAC?
Also the servo clock - should I upgrade this on its own or use the clock signal from the newly installed Audiocom Superclock with a divide by 2 circuit?
Cheers
You can get better but then you're getting to 3 times the price. For about £10 per cap, you can use audio upgrades SI caps. They are also 22,000uF but are even lower ESR. I have about 12 of them in my player now 🙂 It's def worth it if you're looking push the player even further!!
Barry,
Cheers
Send me your address and i'll post it to you. No money required.
There is talk...http://www.national.com/ds/LM/LME49990.pdf
Anyone know about this or if it is applicable to our story?
Great! I read about these on another forum, as a very nice addition to
the Eastern Electric Minimax DAC. Apparently they provide a version already installed on the Brown Dog adapter if I understand correctly.
Ordered 4 off the samples program 8 usd postage 😀 have to make a couple of daughter boards see how they compare to lm4562s.I actually have some on order as samples to test
Brent
cheers alan
Defo yes, when they fired me from my big company I lost at once my e-mail and my free samples!
Were you a human cannonball?
Brent
Brent
Hehe... You should not laught about it..... I was dismissed (along with other 270 people) and I am still flying around 🙁
The specs look good ,
see how they perform .A ki ive got puzzles me skips on track 1 or 2 nothing after that tried loads of other lasers cleaned the spindle amd re greased wierd one.
alam
alam
Strange one Alan. You could try another ribbon. They can cause all sorts of weird problems. Better still, hard wire it.
Hard wiring usually gets rid of all these problems. Bad gnd etc on the ribbon cause no end of reading & tracking errors. Also check R107 for 5V, sometimes this res goes a little high dropping the V after it too much + check the rubber mounts the traverse sits on as these can split and cause the traverse to sit slightly off.
Brent
Brent
- Digital Source
- Marantz CD63 & CD67 mods list
