Hi Simon
The sound is slightly different, it sounds a bit more "raw" "real" edge to it.
Listened to Stevie Wonder Superstition sounded as close to vinyl as i have heard on my system, Snow Patrol i have always found a thick heavy sound is slightly less so, now playing St Germain Des Pres Cafe, this recording is various artists some live in jazz clubs some studio and some vinyl DJ again it all sound more "real"
Treble seems a little less harsh quite interesting!
Just checked something...
When no disc is playing i have a lot of interfence when turning the vol up, admittedly beyond normal playing levels but its there.
Better regulation would be my guess?
Ian
Ian
The hissing / hash type noise is possibly coming from your dac and you are hearing it due to bypassing muting, don't worry
Brent
Brent
I dunno mate. My Philips CD650 has about 5 low noise regs and a fancy output stage and the noise it makes is very loud if you turn the volume up!
I find with fuse and resistor bypasses the sound gains impact. The smoothness you hear is also something I notice when I upgrade mains cables, sockets, plugs, filters etc.
I was missing some text from your message, muting bypass makes sense as i only did that completly after fitting the clock!
Ian
Ian
Last stupid question of the day i promise and off topic, sorry!
Last night i was reading TNT Put a tiger in your amp.
The article is about rubbish trim pots in amps and re biasing them, it states to check the dc output at the speaker terminals, using 200mv range it should be 0mv.
My dmm is auto ranging so i checked i had 1.6 & 1.2, am i seeing an actual reading or does the decimal point need moving?
Sorry to be such a plank😀
LOL
That all depends on what you dvm display was ranging too. It may be 1.2V or 1.2mV or 12mV with a decimal thrown in for good measure lol etc. Do you not have a mV setting on your dvm or a range button?
Brent
Brent
is it harmfull to power only few 5Vs on the cdp without the other devices?
(my dedicated 5V TX and its 317 right on the player).
I've no way to check the decoder and others IC power right from the top, need the beast to be upside-down.
I'm exhausted, done nothing, just opened the lid, checked the room for the +/-10, touched the decoder analog reg and powered up the player. Since then it's dead silent even if I've checked all I can, continuity, resoldered some suspicious points... f!
Hope the decoder is not fried...
Lastly can anyone point me in the direction of CY01 i cant find it😱
Cheers Ian
Hi Ian,
CY01 is located on the display board. If you 'upgrade' RY11 to an inductor, you may experience reduced sensitivity of the remote. The solution is to place a 10...47uF electrolytic cap across CY01.
Regards,
Ray
Ray,
As you're here, do you know reasons why a player will skip when cold?
It's done it since i got it.
Ian
Ian
The grease on the traverse is too thick and once warmed a few degrees it softens. Clean it off all the parts the laser moves over and apply a small amount of new thin grease.
Brent
Brent
It could be your laser is getting weak. As it heats up, the emission increases and the problem disappears. It could also be the discmotor is not rotating freely. If the shaft is a bit dirty, it may stick where it enters the motor when it is cold. When the disc starts to rotate, the sticky grease heats up and becomes more liquid.
If you have a scope nearby, you can check the HF signal and see if the amplitude if o.k.
The entry of the motor shaft can be lubricated with a tiny bit of WD40 for example.
A third possibility could be an IC that is rotten 🙁
Regards,
Ray
Regards,
Ray
Don't like the sound of the 3rd 1🙁
Think i cleaned the hard grease off but can't be sure i got all of it and didn't put new grease in😱
Gonna try to have some fun tomoz, lets see if the local hifi shops will let me put this up against som of thier wares. Lol 😀
- Digital Source
- Marantz CD63 & CD67 mods list
