I've started something now haven't I?
Lee.
LMAO! no more playing for me until at least Wednesday tho!
I'm gonna try with the op amps and filter stage as they are to start, just hook up the TX in line. I've also got a couple of burson's that i could use as single op amps with the filter stage from the DOS before hitting the TX's, but that'll take a little more effort!
For now I'm just glad I'm making sound again!
Is it me or do you only get a small number of posts per page now?????
Glad you got it going Ian
This is my 2nd attempt at modding, but alas No Job No Mod No More
I started not knowing how to open the thing
You guys proved even an idiot can get something from these players, its only lightly modded but its opened my eyes
All closed up for now.........
Thanks for your help guys... Time to start a wish list lol
Hi Simon
Had to do it on the cheap
http://www.audio-gd.com/enweb/pro/diy/JZ-1.htm
Most likely not great but its working
Hi padman
Never say never...... (This is a hooking business)
Ricardo
I kept moaning about the player over the 67
That was so easy to get decent(ish) sound from, i took the advice on here and went for the only option available to me.
Although it's no world beater the clock has transformed it, every aspect has become cleaner, more controlled and more detail than the 67.
I will get some 7805s and work them in directly, i think i see a way of seperating the 4 analogue supplies on the dac and to split the servo dig/ana supplies then run a psu for the clock but for now its ok..
Good work Ian(s), lol.
Padman, I see you changed the two ceramics near Q106 for elco's, nice move that. I can't understand why there aren't any there as standard as that chip draws plenty of current.
And yes, this hobby can be very addictive. Nice to see you back here Ricardo, touched the cdp lately?
Cheers, Lee.
Cheers, Lee.
Just following the rules of Ray lol
It IS addictive i'm sat here thinking of mods on the cheap lol
10 7805s for £3.90 got 1 blackgate 1 470 za and 1 100 zlh plus numerous chokes
Then there is bypassing the fuses and this..................
Maybe i can use it on the clock???
Hi Lee.And yes, this hobby can be very addictive. Nice to see you back here Ricardo, touched the cdp lately?
I have not been bold enough to try any more mods on the cdp... it is sounding better than ever now.... Maybe you will make me look into output tx
Im am busy learning about shunt regs now !
Ricardo
There's loads of cheap lm317 (similar to Ray Regs) available for just over £3 each on ebay!!!
I got 5 with shottky's and 8200uF FC's on them in my 63 now! lol
And 317 sound so much better than the 7805 fixed regs....Very good !
Cheers, Lee.
You make Ricardo sound like a cd fiddler
Brent
If you hook its primary up to the 2 links in the white box (u246 i think) to the keft of you main TX, it'll be switched on and off with the other one. Thats where I hooked all of my primary sides to!
Like Brent already said, its a bit bulky and fairly basic in what it will give you. You'd be better off with a couple of small torroidal tx giving you 4 independant PSU's. As usual, it depends how far you want to go and how much money you want to spend!
In case anyone hasn't seen the "high end" Phonosophie CD player, here's the internal pic from the PDF.
I tried to attach the PDF but I can't shrink it to these silly file size limits.
Simon
LOL
How much is that model? Nice tx and no doubt a decent enough op stage but nothing else is touched!!!!
Brent
I think that is the £3k job with the external 10kg wedding-cake-in-a-hat-box.
The display, chassis and output connectors are all different, and maybe one or two caps but I can't tell - I don't know the CD67 well enough to be sure about it. Pretty obvious it won't have much treble clarity or detail. Those things don't exist just because you put a nice box at either end of the chain.
Simon
Simon
- Digital Source
- Marantz CD63 & CD67 mods list
