Marantz CD63 & CD67 mods list
Thanks for the answers guys!
But I have no Raygulators but the Marantz's 7805 in Q811. The LT1086 fixed 5V should be better there. ( I've Raygs only for opamps supply and a Brent's Super Reg for DAC Analog ). So DAC digital should be better feeded with the LT1086 than the ON Semi 7805 I think. I'll check with the datasheet like Ray said.
Once again I think I will stop modding my CDP, my speakers are no more matching my source and amp, I want to change for better ones and finish my dedicated room, wich are huge improvement !
After these 2 things I will think of going further, maybe an external PSU or Super Regs & discret output... later.
Matthieu
Joined 2006
I believe you will notice a big improvement replacing the stock 7805.
Can you please explain where do you connect the common pin of the sreg you are using in the analog dac ?
I will input 5v on U199 and pic the +10v elsewhere but where must I link the ground? (to U197 or U198 ??)
The star ground is very far away.....
Ricardo
lol. It does look very clean inside now, but I wouldn't recommend it to anyone. I'm really surprised that I got the thing going again, at least it smashed the vase:D
I have one more reg for hf amp to fit, and then it's finished. I can't think of anything else to add to it, except expensive regs and I can't afford any yet!
Lee.
Joined 2006
6h5c said:
The circuit will work woth an 'A' version, but a 'C' version is better. The letter indicates the amplification factor of the transistor, and the 'C' is higher. But you can also use a BC548C, BC549C or BC550C, all the same.
I built a normal reg +5v with two red leds without the capacitor multiplier (I had no C version of the transistor).
In my workbench it oscilates a lot (quite fast from 4.94 to 5.11)
Is it normal ?
Can I use it in the dac ?
Ricardo
Is it normal ?
Ricardo
The fluctuations could be caused by the fact that you have no load on the output. Try to load it with a 10...47u capacitor and a 1k resistor. The output should be rocksolid then. If not, then maybe there's something wrong with your circuit.
Regards,
Ray
Joined 2006
Indeed the load it makes the fluctuations go away...!!!
Thank you Ray.
But i left the circuit burning during the night and now the output is only 2.45 v ...and the leds are not lighted.
I am using very small red leds.
Can this fault be dued to the led types?
Joined 2006
6h5c said:
Are you sure the regulator didn't overheat? They go into thermal shutdown if the temperature becomes too high. If the regulator tab gets too hot to touch after a few minutes, you need a small heatsink.
I really feel the reg too hot.... my bench transformer outputs 30v...
I will get one heatsink.
Nevertheless I replaced the LED by two red 8big size and the output is now 5.01~2 (with load).
I believe I do not need this 1k5 + cap load when feeding the dac.?!
Ricardo
