Hi, I'm looking for some help trying to understand this circuit. The drawer will not open (or close when opened manually). The motor is ok. I have had it working with a 1.5v battery. I do not seem to be getting any voltage to the motor from the board, but i'm unsure as I don't realy know what i'm doing. I've got the service manual but it is beyond me. I also do not seem to have any voltage accross pins 6 and 7 on the philips servo chip to supply it? Any help would be very much appreciated, but remember I am close to being a monkey so a careful explanation is required. Thank you, Barry
If your out there Mooly, I know you would understand. It is similar to the problems I had with the cd6000. Except this is stranger. When I press open/close the disc spins. It will work if I put a disc in and close the drawer manualy!
Yippy, I followed Moolys advise for the CD6000 and found an open circuit resistor on the supply for pin 5 on the 7073A and now it's mended. So thank you Mooly!
