Making M7 Preamp
The balance and volume control circuit
从我的 iPhone 发送,使用 Tapatalk
Connected each GNDs of refunding coupling PCB to the cathode PCB, I used diffefrent colors for each stage.
and connected the GND from input RCA to the case with 100R and 3n3 cap
The amp case has finished connecting wire, in order to avoid noise the power supply wires going through left and the signal wire going through right
