So I've got a 3 way build about to begin... And my midrange is a JBL 2251 10" mid and the plan was to use what I have on hand... That includes either a pair of Selenium D220ti or Celestion CDX1-1745 drivers and these 2 waveguides/horns:
https://usspeaker.com/dds cfd-1-90pro-1.htm
Or
https://www.parts-express.com/B-52-PHRN-1014-10-x-14-Plastic-Horn-Waveguide-299-2303?quantity=1
I'm guessing I want to keep the width of the waveguide closest to the woofer, and the one has a lower C2C distance. As I've not figured out anything other than my midwoofer and bass woofer, I was curious if there was a set of drivers and waveguides that stood out as the obvious choice to start with.
I am starting active and want to make a passive crossover for the MT section, and will be taking measures etc. Just wondering where the best jumping off point is. Thanks
Or
Some might suggest the smallest dimension be at least similar to the wooferI'm guessing I want to keep the width of the waveguide closest to the woofer,
The B-52 waveguide from Parts Express is very good. I am using it myself on a large 2 way active system with a Radian 650 CD and a JBL 2217 woofer. However it's probably not the best choice to mate with a 10" mid. Indeed, the DDS waveguide might not be much better. With a 10" mid you probably want to cross over to the tweeter at about 1.3kHz (assuming you want roughly 90° directivity). Maybe even a tad higher. So a smaller waveguide (like this: https://www.parts-express.com/Dayto...-12-Waveguide-1-3-8-18-TPI-270-318?quantity=1 ) might be a better choice.
I have no direct experience with either of the two CDs you have, but given the relatively high crossover frequency neither one should have much trouble. If I had to choose, I'd start with the Celestion based on what I've read.
Whatever you do, do not throw away those B-52 waveguides. I'll happily take them off your hands for another project I have in mind 🙂
I have those Dayton 6512 already but no screw on drivers... Which is why I was entertaining the other waveguides...
I'd love to find like a JBL 2407 or something but NLA...
JBL 2408, 2408H-1, 2408H-2.I'd love to find like a JBL 2407 or something but NLA...
Are all JBL own development of 2407 which BMS made for them, different phaslugs in 08 and 08H-1. 08H-2 idk.
The diaphragm and chamber is different between 2704 and 2408.
The PHRN waveguide is great with a bolt on driver, and there is a lot of builds with it to look up on the net.
