Making a 2SA798 transistor.
If you clamp them together ident to ident, (the flat front) hook one emitter wire around the other to produce a single wire for connecting. I like the 2N4403 because I don't have to worry about the pin out as it is printed on the front of the transistor. (Must be an age thing).
Make a note of the pin outs before tie wrapping and gluing them together.
I use TBS20S | Electrolube Epoxy Thermal Adhesive, 48 h Cure, 20 ml Syringe | RS Components
I am sure you will be able to source a similar product.
