Updated. I've also opened the doc, so people can freely add their names to the list, or edit their orders.Hello Muddyboots,
Please add 2 boards (total 3)to my order.
Sent from my XT1096 using Tapatalk
Hello Muddyboots,
Thanks for your initiative. I see now the link to the spreadsheet is in the first post of the thread. The column for kits is still in the spreadsheet, while this is not an option anymore.
Did you get my PM, as I would like to send another PM.
Hello Muddyboots,
I did, I apologize I have not yet replied. I will send you a PM now answering your questions.
Yep! I'm still finalizing the layout, but I'm almost done. They're based off of Skrodahl's power supply but they don't have the aux power input and I moved the power in and out to the front for easier access. Might also create a space for heat sinks as well.PSU pcb`s on the spread sheet? Pleeease explain.. 🙂
If you put the regulators on the side of the pcb, they might be able to use the chassie as a heat sink..
Oh now that's an interesting idea.If you put the regulators on the side of the pcb, they might be able to use the chassie as a heat sink..
Hey Gwrskien, I'll have them up either tomorrow night or Monday. Busy weekend over here with family stuff, but they'll be up soon 🙂I see that the bom for the psu is up in the spreadsheet.. Any pic of the pcb?
Finalized the layout of the PSU PCB this morning, I used your idea and put the voltage regulators on the side to use the case as a heat sink. I also spaced out everything to allow for larger components. I'll post pics tonight when I get home.I see that the bom for the psu is up in the spreadsheet.. Any pic of the pcb?
That`s good news! Now if we can find 11 more people that want`s boards, will be at 50pc and $2,8 pr pcb! That is a good price!
Hey Guys,
Here's the images of the DIY Power Supply!
All the routing and component placement is done, I just need to finish with the labels and text and stuff, so this is basically ready to go!
I've also added a third sheet to the sign up form with a BOM for the power supply. It includes a 120v AC-AC adapter that will work with this board, but it is a North American plug, so international buyers please be aware of this and find a suitable alternative.
Also, and this is important, THIS IS AN UNTESTED PRODUCT! I cannot guarantee that it will work perfectly, and by ordering you agree that you are helping to test this product. I am not responsible or liable to any damages to your property. With that said, it is based on a Skrodahl's design with the components moved around for ease of access to wiring terminals and to allow for larger components if one desires.
For the first 10 units ordered they will be $7.80 a piece, with a minimum order of 10. Price breaks will start at unit number 11.
If you want to use a tried and tested design, here are two from theslowdyier in Copenhagen:
https://theslowdiyer.wordpress.com/2015/07/09/project-files-gp-psus-v2/
https://theslowdiyer.wordpress.com/2015/05/05/project-files-universal-triple-psus/
They will not fit in the B0905 enclosure, if that's what you're aiming for.
How does one know what input impedance is needed for their turntable? I have been looking up info for my cart, but I can't find anything about input impedance.
Hi Mobin,
This thread is probably more suitable for your question: Another Super High End Phono Stage! No expense spared... | Audiokarma Home Audio Stereo Discussion Forums
47k ohm is the standard input impedance for a moving magnet cartridge. That might not always be the case though, even if the manufacturer claims so. There's lot of information out there, just google "mm cartridge loading".
Here's one page giving some examples: Load the Magnets!!! - [English]
Since there are so few psu orders compared to muffsy orders, what are you guys using to power this thing with?
I'm guessing they're going to go the battery route? Skrodahl, in your experience how does the audio quality compare using a battery versus using the power supply?
Ooops, I missed the deadline. I added two PSU PCB orders to the spreadsheet for myself after the deadline, so I understand, if those will not be available to me, since I was too late.
9V batteries are typically 500 mAH, which will give you about 20 hours of operating time. Rechargeable batteries have even less, at some 200 mAH. If you're using batteries, SLAs are the way to go and it takes a lot of space. So for me, batteries are out.
I'm currently using an isolated DC-to-DC converter (WRD241212YS-2W pdf, WRD241212YS-2W description, WRD241212YS-2W datasheets, WRD241212YS-2W view ::: ALLDATASHEET :::), and the bypass capacitors on the preamp board are sufficient to smooth out the ripple. I haven't done any measurements, but I can't hear any difference when it's connected to the PSU or batteries.
- Group Buys
- Make Your Own Muffsy Phono Stage Group Buy
