Maby the most costly capacitor on the market
phase_accurate said:
I think it won't be difficult to add heaps of MICA types together to get an even more expensive 20 uF type.
Charles
Then again, Charles, it would be easy to add alot of those 5230 euros caps in a series parallel configuration to have a much more expensive 20 uF type.
What do you think ? 😀
Charles,
here's 24uF styrene , when will you be available to do the soldering ?
(i offer 5 bucks to the one who posts a pic of a twit who bought one of those 5k silver foil caps)
Uh, yes. Ask the Z Machine.
http://en.wikipedia.org/wiki/Z_machine
Megajoules in nanoseconds means high voltages, large capacitances and low, low inductances (probably arranged as transmission lines).
I don't know why people in audio would be asking about paralleled capacitors, just get a Filmlytic and be done with it. If you're not talking about audio, then perhaps you do in fact need high RMS currents; in that case, you might build something like this:
http://webpages.charter.net/dawill/tmoranwms/Elec_CapBank.html
Note the water cooling, which so far I have found unnecessary.
Tim
