MA Alpair winISDpro files?
Leave out some of the values, as WinISD will auto calculate the exact value for certain parameters. An example would be: don't input a value for Vas, if you also input both Mms and Sd. Which driver are you trying to input?
jeff
There is a right way to enter parameters into WinISD:
The suggested procedure for entering driver parameters is following (check first that "Auto calculate unknowns" option is checked):
1. Enter Mms and Cms
This gives fs. If either is not available, then enter fs and other parameter.
2. Enter Sd, Bl and Re
Now, you should get all but Qms (and Qts), Vas. Please note that Vas may not match exactly what is specified by manufacturer, because exact value of Vas depends on environmental parameters. See FAQ.
3. Enter Rms or Qms.
Either one will do, although I tend to prefer Qms over Rms, because it can usually be measured in driver measurement procedures.
4. Enter Hc, Hg and Pe.
If Hc or Hg or either is available, then enter Xmax and optionally either Hc or Hg if available.
5. Enter number of voicecoils.
This procedure is most accurate. Also note that it also calculates true SPL (1W/1m) value. So it might not match the marketing SPL value, which is generally somewhat vague. Not in all cases, though.
6. Correct Znom, if necessary.
If there are several voicecoils, then you must be careful when entering parameters in that case, because many manufacturers give Bl in voice coils in series, because it yields double value for Bl against parallel connection. If driver manufacturer gives Qes, Bl and Cms or Mms, then you can check how Bl is specified. For that, you can enter following parameters to calculate Re: Qes, Fs, Mms or Cms and Bl. Connection mode can be changed by changing the combobox selection. The driver editor then converts Bl and Re values accordingly.
Equivalently, you can check for Bl by entering:
Qes, Fs, Mms or Cms and Re (for desired connection mode).
If you enter resistance for parallel connection and get about half of advertised Bl, then you know, that Bl was specified that way.
Like in Driver-tab in project window, you'll probably noticed the driver icon in bottom of the driver editor window. you can drag the driver object into some project by just dragging the icon.
Start the program. Select "New Project" from top tool bar. A dialogue box (select driver for project) will pop up. Select "New". The driver dialogue box will pop up. Add the driver make and model number. Click on "Parameters" and add Qes, Qms, Fs, Sd, Re, Vas. The program will auto calculate Qts and Mms. That's all you need to get started. Save, and close dialogue box.
To load your new driver, select "New Project" again and scroll down in the dialogue box for your driver. Click "Next" and choose box type (sealed or vented), alignment (QB3 is usually the best to start), and "finish". The program will auto calculate a box size and tuning. You can change this to suit your own design.
jeff
sd ?
i think there is a problem with SD .What is that ''K'' ?
1000 times thank you for help
best results today
i own you some beers , just give me your mail for paypall
I still think I made some thing wrong but that's a big improvement
thank you
bye the way ,I uploaded the wdr file ,maybe someone would like to take a look at it .
