M-125 Monoblock Debugging Advice
So OK, you need to make sure that grid resistor (100k) are all grounded, esp you have auto-bias that will try to correct itself, but the volume level could be affected.
One more snapshot, it appears there is missing/extra wire, see attached.
Thanks. The grid resisters look well grounded, but I will resolder them. Sorry but I am not seeing the missing wire you are talking about. The wires connecting pins 1 and 6 (v1 to v3, and v2 to v4) were removed as part of the autobias install. Are these what you mean?
I see a total of 6 red wires running to V-3 (the left socket) in snap-2. The top 2 (pins 2 and 7) are blue in snap-1. The right 2 (pins 3 and 4) are orange in snap-2. The bottom/left 2 (pins 4 and 6) are red in snap-2. Sorry, not seeing the extra wire.
Why the white wire is not there: From the autobias instructions:
1. Remove the two 10 OHM bias resistors connected to pins 1&8 on the two output tube sockets,
marked with a RED X on the photo
2. Remove the wires, marked in white on the above photo, between pins 1 of the tube sockets for
V1 to V3 and V2 to V4
3. Remove the wires, marked in white on the above photo, between pins 6 of the tube sockets for
Thank you for your help, I appreciate it very much. I think you are asking me to measure resistance between pin 5 and ground. My reading is 5.4 M
On the wiring diagram from the M-125 instructions which I posted earlier, there is no wire between pin 6 and the grid resister. The grid resister is 100 ohms, not 100K ohms.
For pin 6:
- it shows v3 out and v4 out from the driver board going to v3 and v4 respectively.
- V3 and V1, and V2 and V4 tied together (removed per autobias)
- the IK resister between pins 5 and 6.
No other connections to P6
The 100 ohm resister connects to pin 3. Per the wiring diagram pin 3 (V3 and V4) have connections from the output transformer (blue and striped blue wires) and a connection P6 to P6 to both V1 and V2.
No no..100 ohms is anode resistors. R32, R30 and R32B, R30B are grid 1 resistors 100k, I can see R32B, R30B on auto bias module. You have all the 4 missing or not connected or connected but not ground. The other wire from pin 6 is connected to the coupling capacitor appear to be on auto bias module, otherwise there will no output.
This module appears to be CCS constant current source that limit the tube current (so it does draw too much current even you don't have any grid1 resistor connected). Read the schematic instead of the instruction as there are mistakes..I can't believe that is the right instruction you posted earlier..
OK, I understand better what you are saying. R30 and R32 (V3, V4) are on the driver board. R30B and R32B (V1, V2) are on the autobias board. All 4 100K resisters are present. V1 and V2 GRD are connected to R30B and R32B as part of the pcb layout. V3 and V4 GRD connect to the driver board and presumably have the 100K resisters in the path. I need to verify that. V1 out and V2 out are connected tro P6 on V1, V2 respectively.
Exactly where should I measure to determine if the 100K grid 1 resisters are connected?
