Lyra Kleos & Jean Hiraga's Pre-Pre-Amp (from Magazine "L'AUDIOPHILE")
A good friend of mine would like to operate this cartridge under
Lyra Kleos Phono Cartridge | Analog LP + MC Cartridge
Lyra Kleos - Kleos bedeutet „Ruhm“ - FIDELITY online
Mein Lyra Kleos SL ist da - mein Gott, was fur ein Erlebnis !! - Seite 5 - Tonabnehmer und Tonarme - Analogue Audio Association
with this moving coil head amp, described in English under
Project | Homebuilt Hi-Fi - A user submitted image showcase of high quality home built hi-fi components.
Hiraga MC Preamp
https://web.archive.org/web/20110106161058/http://diy-audio-world.com/HiragaPrepre.htm
https://www.lencoheaven.net/forum/index.php?topic=12916.0
http://leachlegacy.ece.gatech.edu/headamp/
and in German under
https://www.rstaudio.de/mc1-hiraga-mc-vorvorverstaerker/
http://www.stereoxl.de/images/PDFRezensionen/analog_2013_1_58 - 63_Der PrePre_Hiraga.pdf.pdf
http://methe-family.de/phonopre.htm
https://www.analog-forum.de/wbboard...nehmer-in-basisschaltung-wie-hiraga-mc-pream/
https://www.analog-forum.de/wbboard/index.php?thread/39811-hiraga-prepre/&pageNo=6
https://www.analog-forum.de/wbboard/index.php?thread/116012-stromversorgung-für-le-prepre/
https://www.analog-forum.de/wbboard...21-hiraga-le-prepre-für-niederohmige-systeme/
https://www.analog-forum.de/wbboard/index.php?thread/95290-mc-prepre-im-selbstbau/
https://www.audiovintage.fr/leforum/viewtopic.php?t=36238
According the schematic there is no capacitor between the cartridge coils and the emitter (comon base) input.
This means, there is a certain risk that could be caused an issue by residual DC and noise by switch-on.
Maybe there are countermeasures (as an extension of Hiraga's circuit) to avoid resp prevent such issues.
Thank you very much for advices.
Check out in this case this threads:
DC Coupling for MC Cartridges - how much error voltage before coil damaging
Audio Research MCP 33
Allowable DC Current for a Phono Cartridge
Hiraga MC Preamp
and in German under
What is the maximum permissible voltage drift (in order to offset adjust)?A good friend of mine would like to operate this cartridge under
Hiraga MC Preamp
Diy Audio World
And what is the best approach against DC and switch-on pops on cartridge coils, if one want to use Jean Hiraga's Pre-Pre-Amp ?
Thanks for upload an appropriate circuit.
The mentioned projects in post #1 don't use any protect steps for the DC connected MC cartridge.
