LYNX amp problems...Help
The voltage across the emitter resistors will always be "right" with reference to the cap polarity, however the cap is charges/discharges by 100R resistors R124/126 and R125/127.
A rapid change in output signal could cause a small reversed voltage over the caps, as they have to discharge through the 100R resistors.
Many uses normal caps in this circuit, however if you look at the proff studio amplifiers, many chooses to use NP-caps for secure and long living. Remember this amp is intended to be driven to it's limits over longer periods😉
As I stated earlier, the maximum reversed voltage can be 1.6V.
I haven't yet made concrete measurements, but better safe that sorry 😉 1.6V reversed are not much, however in an amp rated for 24 hours/7 days a week heavy duty, I think this absolutely prolongs the life time of the caps if they are NP-caps :nod:
By the way
Complete 2 channel PCB layout with Silk Screen, Bottom, Paste and Resist layers has been uploaded on my website:bigeyes:
You get reverse voltage in total due to currents flowing in the shunts but no current is flowing actually backwards => no reverse voltage at the cap.
Note also that the two diodes are probably unnecessary beacuse the base-emitter junction act like a diode and can take rather much current. One diode in the transistor in parallel with diodes => the single diode wins.
Nice CAD job Jan but I wonder one thing: Why don't you place the part names so you can see them when all parts are soldered in? Much easier when you want to troubleshoot or just test.
Perhaps then we can try out "burning" and stressing the amps seperately to see which ones fail first~!...lolx...I'm currently waiting for the PCBs...got all the parts laid out on my table...waiting sux...I use MJL3281As and MJL1302As though...as outputs...other parts are the same...'cept for the NP cap...lolx
