Where did you get them??
I need to find some...I know RS carries them...but I hate their delievery charge...often it's higher than the stuff I get...unless I plan to get some trafos from them...
Jan,
Thanks for the upload! I got my copy just now. I see that you used 340/350 as the predrivers instead of the 15032/33 pair. Anyways, thanks man! 😎
JojoD
JojoD
li_gangyi
These are from RS.
However you can use normal caps instead of the NP-Caps😉
Jojo
My component list are only suggestions!!!!
It works fine with both types
We have just has a major Power Down (6 hours) on the electricity net here in eastern Denmark and southern Sweden, so I won't be able to upload more today.
However I hope to be finished tomorrow (if the electricity don't fall out again
These are from RS.
Jojo
If you are not using NP-caps but "normal" caps, you should use two to make a Non-Polarity cap 😉
If you connect the two negative terminals on two normal caps together you got a NP-Cap
Like this:
lead------ (+ cap -) -----lead----- (- cap +) ------lead
Like this:
Yeah I know that trick ACD...but that would mean I would need tow caps that are twice the original Value...in this case series connecting 2 44uF caps will give me a NP 22uF cap...as for the bridging problem...I think that's perfectly possible...just use a simple opamp circuit to "split-up" the sound signal and apply it to 2 amps...and then jion both speaker wires to the positive of the amps...remember not to ground any side...
Welcome to UrSv
Yes! This amp is perfect for bridging. You just need a seperate circuit with an Opamp and 4 10K resistors to invert the signal to one of the amplifier circuits🙂
Li:
The value of these NP-caps are not so important, as they only goes into action, when the current limiter circuit strikes.
I wonder why it is so difficult to get NP-caps where you live
Li:
Hi all,
I finished Yesterday the LINX amp. It has really good bass, and can drive anything down to 2ohms.
I used MJL21193/94, MJE15030/31, and MJE340/350 for the output stage.
I made some modification, as I add DC servo for the circuit and I used NE5532 for input and DC servo application.
Sajti
Sajti
Sajti
Always nice to hear a respond, when people build your stuff 😉
Congratulations
and thanks 😉
Yes! DC-servo can be used, however I have observed a weaker bass response when using DC-feedback and servo's.
As this amp amplifies DC, it's necessary to use a very low DC-offset opamp
The first version I made used a DC-offset trimmerpot to on pin 3 of the opamp, to remove the DC-offset🙂
Congratulations
I had no problem with the bass. I set the DC servo frequency to 0.2Hz, and I use 2nd order filter, to avoid bass cut, and noise.
The output DC offset was less than 1mV over hours.
Sajti
Sajti
Jan (ACD), note that you have written mH instead of microHenry for the output filter. Also, this "L" can usually be 0.5 uH - 2 uH, not very critical.
I'm not so sure why I cannot find NP caps here easily...other than from RS...which costs a lot to ship here...so I'm just taking an easy way out...hehe
- LYNX amp problems...Help
