The Lundahl is good for TU-8200 and TU-8200R.
I will have the first sample next week..
This Lundahl is similar to the Lundahl of TU-8800.
It is time consuming to make it
Are you go going to offer the 8200-R with the Lundhal OPT as part of a kit for a first time build as well (instead of just an upgrade to an already built model)? If so, I’d be interested in that. Thanks.
Thanks Victor. Nice.
So we can expect the same specs but possibly better performance from the Lundahl touch.
Victor,
Please is the Lundahl 6.0 volts as the stock transformer or is 6.3 V ( or a different value)?
Sandor
Sandor
You may have misunderstood something. These Lundahls are output transformers, the power transformer and its winding for heaters remain the same.
Lundahl LL2777B is available next week
It is $310 a pair with PCB Board + HV cables.
The construction of LL2777B is same as LL2783C (TU-8800).
Hi Victor, be so kind and reserve one pair of Lundhals for me please. How should I make an order and payment? I would like to buy one piece of the TKD 2CP-601 PCB for TU-8600SVK and one piece of the TKD 2CP-601 potenciometer too, if you have it on stock. Thank you very much.
in ordrr to do a good job , the thickness of the solder should be around 0.3~0.35cm
https://flic.kr/p/2k6BeSr https://www.flickr.com/photos/64593884@N08/,
https://flic.kr/p/2k6FDtq https://www.flickr.com/photos/64593884@N08/,
https://flic.kr/p/2k6FDun https://www.flickr.com/photos/64593884@N08/,
