It looks like a fine audiophile type of speaker, with low distortion and low sensitivity, good for a small room. It's not clear to me if it will reach your SPL requirement of 100dB.
But loudness aside, which one will have better sound quality?
That's a very loaded question really, I could say I prefer the sound of the revelators while someone else might prefer the sound of the Seas drivers.
I'm biased because that Scan-Speak kit has the woofer driver that I've been wanting to try for a long time, but haven't because of the price, so I'd be all over that Lumine kit. 😉
It's hard to say without listening to them and measuring them. The Bifrost has very low distortion, but the Lumine One doesn't have the same data, so I can't tell. I think you're stuck with calling up Madisound and asking them since they have direct experience with these.
If they are that close then it is a loaded question I agree.
Im going to give them a call shortly.
Its also interesting that seas (the manufacture) created that kit and has the plans for the box on their website. The scan speak kit looks like madisound created the kit.
If you have the tools and the skill to use them, I'd go with that one.
what skills do I need? Ordering the kit looks fairly straight forward and it looks like it comes with all crossover parts needed. I can solder with ease. I have a drill press so I can modify the tweeter and the wood working looks fairly easy also.
I'm curious why you would choose that one over the other though? Higher sensitivity?
I don't know. You should ask the designer. Did you ever call Madisound? What did they say?
I talked to Matt. He basically said not to waste them on rears as they were really intended to be mains. He recommended that i start out on some Zaph SR-71's
He also said that the lumine one 2 way kit was in a much different class then the quattro. The quattro used much much cheaper drivers.
OK. Then I'd do that. Good luck.
Thanks for all the help. Any ideas on which crossover to get? What is the difference?
i think the price of the drivers is not the only parameters to determined the performances.
judging from the well documented project by troels, not to mention he did design the woofer to achieve high efficiency with higher rolloff, which most of the time is a good thing. i would go with the quattro.
i always prefer bigger cones and high eff with good power handling. so u can use lowered power class A amp.
cheers
henry
cheers
henry
- Lumine One 2-Way Speaker Kit
