LTSpice FFT simulation settings and inconsistent results.
The simplest multi-tone analysis is just two sine waves, frequency shifted so they heterodyne to make a signal with a sine-shaped envelope. This is basically the same thing as a sine-burst signal. Here is a amp test rig I made set up for CCIR.
If you want to do multi-tone analysis you must really remember the "noise floor" in SPICE doesn't mean anything, and it has to be low enough before you will get meaningful results. A high noise floor in simulation indicates the simulator is not set up optimally. This rig attempts to correct that.
  • ampsim5_CCIR.asc
Ex-Moderator
Joined 2011
Thanks, this is very useful information.
