Hello Guys,
Here are the prices for the SMD version and THT version.
Specs are 1.6mm, FR-4, 70um copper, HASL, Green masked.
SMD version (33.78mmx 29.97mm), price 1USD per piece (single pcb) OR 2 USD per pair
THT version (33.78 mm x 50.55 mm), price 1.7 USD per piece (single pcb) OR 3.4 USD per pair. Paypal and shipping extra.
Please order in pairs for convenience. e.g. If you need 10 of the THT and 8 of the SMD, please mention
Prasi, SMD-4 pairs, THT-5 pairs
The individual pairs will have V-grooving in the middle , so users can either use them separately or in pair.
The SMD can have the mosfet in SOP-8 advance, SO-8, etc packages and have both SMD (DFN-8) and DIP-8 package alternatives for LT4320.
For THT, it will be TO-220 for MOSFET and DIP-8 for LT4320.
Here is how the panel looks like.
Prasi
Prasi
Hello Guys,
Prasi
Hi, Prasi
Looking good! Looking at the image, it seemed to me that there are holes for stand-off for the THT board (correct me if I am wrong)but not the SMD version (probably due to size consideration)? I am wondering what would be a good way to "fix" the SMD bridge inside an amp so it won't move.
By the way, do you think you can get me an estimate on shipping to Canada for 4 pairs of each version?
Thank you very much for making this happen. Your effort is very much appreciated!! Have a good day!
Prasi,
Sorry, one last question. What is the package size of the SMD components (caps and resistors) specified? My eyes are not good enough for the small sizes components (I don't have a microscope)😱.
Thanks!
Thanks!
Hi, Prasi
Hello Lo,
The SMD version is intended to replace the SIP-4 type packages
Like the following
1. http://www.szhaina.com/uploads/media/20171019/1508375287.pdf
2. https://www.mouser.in/datasheet/2/427/pb3506-247509.pdf
So it can be soldered into the holes like the attached image.
The small caps resistors and LED are in 1206 package. A small 10uF electro cap can be made to stand above the board.
Prasi
gary s, THT- 5 pairs.
Fab, THT-6 pairs, SMD-2 pairs
danny_66, THT - 10 pairs
Thanks!
Thanks!
Cerole, SMD-5 pairs, THT-5 pairs
Thanks!
Thanks!
Hello Lo,
Like the following
Prasi
Prasi,
Thanks!!
danny_66, THT-10 pairs, SMD-5 pairs
Thanks!
Thanks!
Lo_Tse, SMD - 4 pairs, THT - 4 pairs
Thanks!
Thanks!
av-trouvaille: THT - 10 pairs
How is this paired with the new CRC psu boards that Prasi's running a group buy?
GB: CRCRC PSU
Does this replace the diode section of the psu board to make it more like an outboard type (aka bridge rectifier).
thanks
GB: CRCRC PSU
thanks
For the SMD version, it will be a plug-solder and play, just like the tester lt4320 boards you already have. The solder pads are given between the diode heatsinks.
For the THT, it can be mounted separately like a regular rectifier and then run wires from the rectifier boards to the CRCRC in places marked DC+/GND/DC-
Thanks Prasi, then I am interested in the through hole as the SMD is difficult for me to solder 🙂
I believe 1 pair of boards is need for each of the CRC psu board right?
manniraj: THT - 4 pairs
Corrected the list.
Corrected the list.
Each Board can be considered as an individual rectifier, so 2 boards would be required for CRC/ CRCRC pcb.
listener42: THT - 4 pairs
Pinnocchio, SMD - 4 pairs (if they're the same rev I have, then just add 2 pairs), THT - 4 pairs
- Group Buys
- LT4320 based active rectifier
