Lt1963 v out cap
Joined 2018
I have some Aliexpress regs using the 5pin Lt1963. They measure 5v out just fine but I have also measured the caps. Input caps are somewhere between 7 and 10uf over the 5 regs I bought which is within spec of the LT datasheet.
However the output caps are woefully under sized and measure 80nf.....0.08uf.
Should I replace with a new 0805 >10uf X5R.
Or parallel an electrolytic and maybe also a 0.1uf film over the existing 80nf.
Or is there a better alternative.? Won't be drawing much current. They will be powering individual dac chip rails
Few people realize to what extent the change is.
LT1963 is my favorite OEM poz regulator, but noting this, the ESR of the output cap plays a huge role in stability.
By sweeping the load current one can judge the stability of a regulator with feedback. This example assumes a 10uF with ESR of 1milliOhm, 100milliOhms and 1 Ohm:
