Digi-Key - S9016E-07-ND (Manufacturer - GRPB071VWCN-RC)
Pull out pin 2, 4, 6. Then you are left with 4 pins for drains & source.
A 3-pin version with pin 2 removed will take care of the 2 gates on the reverse side of the PCB.
Low cost, easy to get .... 😉
Patrick
Patrick
Patrick
🙂 perfect idea, you found, but after removing 2, 4, 6 it should be possible
to use 2 of them on the other side.
Michael
If you can get 0.5mm (or even better at 0.4mm) thick PCB, then they will be perfect as the plastic part is 2.14mm thick.
So the 2 rows of pins (D & S on front side, gates at the back) will end up almost exactly 2.54mm apart, as in 2SK389.
Patrick
Patrick
Adaptor Board
After a busy week I ordered the boards today and expect to
receive them in 2-3 weeks.
Price is 4 EUR / 10 boards + 1,50 EUR pp as standard letter.
If you like this pin header:
may be shipping might be a little higher.
Please send an e-mail to mgriessbach@ctech-suew.de
with
1. quantity boards you want
2. quantity pinheader
3. shipping address
regards Michael
with
3. shipping address
regards Michael
Michael,
If you want to be totally compatible to the 2SK389, you will need
1x S9016E-07-ND AND 1x S9016E-03-ND (I am afraid)
so that you can have the 2 gate pins offset to the drain & source by 2.5mm.
Patrick
Patrick
It's finally ready? Do you create a GB where people can ask they wants? prices, expected time to receive the adaptors,etc. As I understood the adaptor will be to replace the trough hole 2SK389BL, right?
Thanks a lot in advance
Best
Best
I still have a bunch of adapters that I made back in the day, if anyone wants some.
The pins are installed first, then the device is soldered on top. The trick is to place the pins inside a zigzag socket (or using the PCB that you're about to install the device in as a guide works) while soldering the pins and the device.
I like Patrick's solution though, but I've done probably 25 or so in the above manner, so it can be done.
My solution is better. Less footprint, easier to solder.
Michael is busy. I also have not heard from him.
But we agreed to order enough for everyone.
And price will be much less than 1 Euroa piece, but depends how many can be accounted for.
Be patience,
Patrick
Be patience,
Patrick
Short Update :
Boards production ist confirmed and delivery to me scheduled for 06/28.
So I'll get them at beginning of Juli.
Michael
Michael
Looks good.
Use straight headers and each one does his own DIY pin header bending. 😉
The DK headers are way too expensive. Great work Michael.
Patrick
Patrick
Looks perfect, nice work congratulations, I mind it's time to create the GB & start to send money?
- Group Buys
- LSK389C SOIC-8 Group Buy
